Mismatch in explicit fortran interface for MatGetInfo
Stephan Kramer s.kramer at imperial.ac.uk
Sat May 30 11:11:30 CDT 2009
Satish Balay wrote:
> On Sat, 30 May 2009, Stephan Kramer wrote:
>> Thanks a lot for looking into this. The explicit fortran interfaces are in
>> general very useful. The problem occurred for me with petsc-3.0.0-p1. I'm
>> happy to try it out with a more recent patch-level or with petsc-dev.
> Did you configure with '--with-fortran-interfaces=1' or are you
> directly using '#include "finclude/ftn-auto/petscmat.h90"'?
Configured with '--with-fortran-interfaces=1', yes, and then using them
via the fortran modules: "use petscksp", "use petscmat", etc.
> With my builds --with-fortran-interfaces=1 is broken with p0 [so p1
> might also be broken] There was some reorganizing of f90 interface in
> the newer patchlevel [p4/ or p5] - and thats also broken [so petsc-dev
> is also broken]
>> My current workaround is to simply wrap the call the MatGetInfo inside an
>> external subroutine that doesn't use the fortran interfaces, so we can still
>> apply the interfaces in the rest of the code. This is part of our CFD code
>> that has to build on a number of different platforms, so I will probably have
>> to maintain this workaround, so it will build with whatever petsc 3 version is
>> available on a given platform.
>> The attached files were for current petsc-dev?
> Thare are from petsc-3.0.0 - but it should also work with
> petsc-dev. Its tested by building PETSc normally - and changing the
> example ex12f.F as follows:
> asterix:/home/balay/tmp/petsc-dist-test>hg diff src/ksp/ksp/examples/tests/ex12f.F
> diff -r 981c76f817e6 src/ksp/ksp/examples/tests/ex12f.F
> --- a/src/ksp/ksp/examples/tests/ex12f.F        Tue May 26 22:13:06 2009 -0500
> +++ b/src/ksp/ksp/examples/tests/ex12f.F        Sat May 30 11:02:03 2009 -0500
> @@ -8,6 +8,10 @@
>  #include "finclude/petscpc.h"
>  #include "finclude/petscksp.h"
>  #include "finclude/petscviewer.h"
> +#define PETSC_USE_FORTRAN_INTERFACES
> +#include "finclude/petscmat.h90"
> +#undef PETSC_USE_FORTRAN_INTERFACES
>  !  This example is the Fortran version of ex6.c.  The program reads a PETSc matrix
>  !  and vector from a file and solves a linear system.  Input arguments are:
> Satish
I'll have a go at it
>> Cheers
>> Stephan
>> Satish Balay wrote:
>>> I have the following fixed files [untested yet]. But could you tell me
>>> how you've configured PETSc? - and what patchlevel?
>>> [It appears that there are quiet a few breakages with
>>> --with-fortran-interfaces=1 - I might fix this in petsc-dev - not
>>> 3.0.0 - as it depends upon some f90 interface changes that are only in
>>> petsc-dev]
>>> Attaching the modified files that go with my untested fix.
>>> include/finclude/ftn-auto/petscmat.h90
>>> include/finclude/ftn-custom/petscmat.h90
>>> src/mat/interface/ftn-auto/matrixf.c
>>> src/mat/interface/ftn-custom/zmatrixf.c
>>> src/mat/interface/matrix.c
>>> Satish
>>> On Wed, 27 May 2009, Barry Smith wrote:
>>>>  Stephan,
>>>>   Satish is working on the patch for this and will get it to you shortly.
>>>>   Sorry for the delay, we were debating how to handle it.
>>>>    Barry
>>>> On May 23, 2009, at 9:00 AM, Stephan Kramer wrote:
>>>>> Hi all,
>>>>> First of all thanks of a lot for providing explicit fortran interfaces
>>>>> for
>>>>> most functions in Petsc 3. This is of great help. I do however run into
>>>>> a
>>>>> problem using MatGetInfo. The calling sequence for fortran (according to
>>>>> the
>>>>> manual) is:
>>>>> double precision info(MAT_INFO_SIZE)
>>>>> Mat <cid:part1.02040105.02020103 at imperial.ac.uk> A
>>>>> integer ierr
>>>>> call MatGetInfo
>>>>> <cid:part2.00070305.02060306 at imperial.ac.uk>(A,MAT_LOCAL,info,ierr)
>>>>> The interface however seems to indicate the info argument has to be a
>>>>> single
>>>>> double precision (i.e. a scalar not an array). I guess with implicit
>>>>> interfaces this sort of thing would work, but with the provided explicit
>>>>> interface, at least gfortran won't let me have it.
>>>>> Cheers
>>>>> Stephan
