Mismatch in explicit fortran interface for MatGetInfo
Sat May 30 11:02:56 CDT 2009
On Sat, 30 May 2009, Stephan Kramer wrote:
> Thanks a lot for looking into this. The explicit fortran interfaces are in
> general very useful. The problem occurred for me with petsc-3.0.0-p1. I'm
> happy to try it out with a more recent patch-level or with petsc-dev.
Did you configure with '--with-fortran-interfaces=1' or are you
directly using '#include "finclude/ftn-auto/petscmat.h90"'?
With my builds --with-fortran-interfaces=1 is broken with p0 [so p1
might also be broken] There was some reorganizing of f90 interface in
the newer patchlevel [p4/ or p5] - and thats also broken [so petsc-dev
is also broken]
> My current workaround is to simply wrap the call the MatGetInfo inside an
> external subroutine that doesn't use the fortran interfaces, so we can still
> apply the interfaces in the rest of the code. This is part of our CFD code
> that has to build on a number of different platforms, so I will probably have
> to maintain this workaround, so it will build with whatever petsc 3 version is
> available on a given platform.
> The attached files were for current petsc-dev?
Thare are from petsc-3.0.0 - but it should also work with
petsc-dev. Its tested by building PETSc normally - and changing the
example ex12f.F as follows:
asterix:/home/balay/tmp/petsc-dist-test>hg diff src/ksp/ksp/examples/tests/ex12f.F
diff -r 981c76f817e6 src/ksp/ksp/examples/tests/ex12f.F
--- a/src/ksp/ksp/examples/tests/ex12f.F        Tue May 26 22:13:06 2009 -0500
+++ b/src/ksp/ksp/examples/tests/ex12f.F        Sat May 30 11:02:03 2009 -0500
@@ -8,6 +8,10 @@
 #include "finclude/petscpc.h"
 #include "finclude/petscksp.h"
 #include "finclude/petscviewer.h"
+#define PETSC_USE_FORTRAN_INTERFACES
+#include "finclude/petscmat.h90"
+#undef PETSC_USE_FORTRAN_INTERFACES
 !  This example is the Fortran version of ex6.c.  The program reads a PETSc matrix
 !  and vector from a file and solves a linear system.  Input arguments are:
Satish
> Cheers
> Stephan
> Satish Balay wrote:
> > I have the following fixed files [untested yet]. But could you tell me
> > how you've configured PETSc? - and what patchlevel?
> > [It appears that there are quiet a few breakages with
> > --with-fortran-interfaces=1 - I might fix this in petsc-dev - not
> > 3.0.0 - as it depends upon some f90 interface changes that are only in
> > petsc-dev]
> > Attaching the modified files that go with my untested fix.
> > include/finclude/ftn-auto/petscmat.h90
> > include/finclude/ftn-custom/petscmat.h90
> > src/mat/interface/ftn-auto/matrixf.c
> > src/mat/interface/ftn-custom/zmatrixf.c
> > src/mat/interface/matrix.c
> > Satish
> > On Wed, 27 May 2009, Barry Smith wrote:
> > >  Stephan,
> > >   Satish is working on the patch for this and will get it to you shortly.
> > >   Sorry for the delay, we were debating how to handle it.
> > >    Barry
> > > On May 23, 2009, at 9:00 AM, Stephan Kramer wrote:
> > > > Hi all,
> > > > First of all thanks of a lot for providing explicit fortran interfaces
> > > > for
> > > > most functions in Petsc 3. This is of great help. I do however run into
> > > > a
> > > > problem using MatGetInfo. The calling sequence for fortran (according to
> > > > the
> > > > manual) is:
> > > > double precision info(MAT_INFO_SIZE)
> > > > Mat <cid:part1.02040105.02020103 at imperial.ac.uk> A
> > > > integer ierr
> > > > call MatGetInfo
> > > > <cid:part2.00070305.02060306 at imperial.ac.uk>(A,MAT_LOCAL,info,ierr)
> > > > The interface however seems to indicate the info argument has to be a
> > > > single
> > > > double precision (i.e. a scalar not an array). I guess with implicit
> > > > interfaces this sort of thing would work, but with the provided explicit
> > > > interface, at least gfortran won't let me have it.
> > > > Cheers
> > > > Stephan
