include file fortran
Fri May 15 17:37:11 CDT 2009
On Sat, 16 May 2009, Tahar Amari wrote:
> The reason is that :
> I am developing different codes . Some are
> in fortran, others in C and others in C++.
> Why should I built only the fortran please ?
You either build C/fortran or C++/fortran.
> I did make tests and those were OK. Do you mean it is not sufficient ?
Yes this is sufficient.
You can have a single C++/fortran build of PETSc and use from all the
3 cases above [usually - by compiling your c application as c++].
Satish
