include file fortran
Tahar Amari amari at cpht.polytechnique.fr
Fri May 15 17:39:03 CDT 2009
Thanks a lot
for this information.
Tahar
Le 16 mai 09 à 00:37, Satish Balay a écrit :
> On Sat, 16 May 2009, Tahar Amari wrote:
>> The reason is that :
>> I am developing different codes . Some are
>> in fortran, others in C and others in C++.
>> Why should I built only the fortran please ?
> You either build C/fortran or C++/fortran.
>> I did make tests and those were OK. Do you mean it is not
>> sufficient ?
> Yes this is sufficient.
> You can have a single C++/fortran build of PETSc and use from all the
> 3 cases above [usually - by compiling your c application as c++].
> Satish
