include file fortran
Tahar Amari amari at cpht.polytechnique.fr
Fri May 15 17:29:55 CDT 2009
The reason is that :
I am developing different codes . Some are
in fortran, others in C and others in C++.
Why should I built only the fortran please ?
I did make tests and those were OK. Do you mean it is not sufficient ?
Tahar
Le 16 mai 09 à 00:21, Satish Balay a écrit :
> If using PETSc from fortran - why use --with-clanguage=cxx ?
> Also - verify if PETSc examples work - before attempting your code.
> And then use PETSc makefiles.
> [i.e copy the makefile from PETSc example dir - and modify the target
> to build your code]
> Satish
> On Sat, 16 May 2009, Tahar Amari wrote:
>> Just to let you know is that I built petsc with c++ anyway since I
>> did
>> configure -with-cc=gcc --download-mpich=1 --download-parmetis=1
>> --with-#shared=0 --download-f-blas-lapack --with-clanguage=cxx --
>> with-cxx=g++
>> --with-fc=ifort --with-dynamic=0
>> Tahar
