PCNN-preconditioner and "floating domains"
Andreas Grassl Andreas.Grassl at student.uibk.ac.at
Tue Jun 23 11:15:39 CDT 2009
Barry Smith schrieb:
>    As we have said before the BNN in PETSc is ONLY implemented for a
> scalar PDE with
> a null space of the constant functions. If you shove in linear
> elasticity it isn't really going to work.
Do you have any suggestions to work around this drawback?
Do I understand right, that this issue is problematic, if floating subdomains
appear?
Do I have the possibility to provide the null space from user site?
Or how big would be the effort to change the nn-code to work for this problem
classes?
Is such a work useful at all or do you regard BNN only a rather complicated
method to be done much better by other (even simpler) algorithms?
Cheers,
Ando
 /"\                               Grassl Andreas
 \ /    ASCII Ribbon Campaign      Uni Innsbruck Institut f. Mathematik
  X      against HTML email        Technikerstr. 13 Zi 709
 / \                               +43 (0)512 507 6091
