PCNN-preconditioner and "floating domains"
Tue Jun 23 11:23:21 CDT 2009
    To modify the code for elasticity is a big job. There are two
faculty Axel Klawonn and O. Rheinbach
at Universität Duisburg-Essen who have implemented a variety of these
fast methods for elasticity.
I suggest you contact them.
    Barry
On Jun 23, 2009, at 11:15 AM, Andreas Grassl wrote:
> Barry Smith schrieb:
>>   As we have said before the BNN in PETSc is ONLY implemented for a
>> scalar PDE with
>> a null space of the constant functions. If you shove in linear
>> elasticity it isn't really going to work.
> Do you have any suggestions to work around this drawback?
> Do I understand right, that this issue is problematic, if floating
> subdomains
> appear?
> Do I have the possibility to provide the null space from user site?
> Or how big would be the effort to change the nn-code to work for
> this problem
> classes?
> Is such a work useful at all or do you regard BNN only a rather
> complicated
> method to be done much better by other (even simpler) algorithms?
> Cheers,
> Ando
> /"\                               Grassl Andreas
> \ /    ASCII Ribbon Campaign      Uni Innsbruck Institut f. Mathematik
>  X      against HTML email        Technikerstr. 13 Zi 709
> / \                               +43 (0)512 507 6091
