PCNN-preconditioner and "floating domains"
Tue Jun 23 09:34:11 CDT 2009
    As we have said before the BNN in PETSc is ONLY implemented for a
scalar PDE with
a null space of the constant functions. If you shove in linear
elasticity it isn't really going to work.
    Barry
On Jun 23, 2009, at 8:56 AM, Andreas Grassl wrote:
> Hello again,
> the issues from my last request regarding VecView and data
> distribution among
> the different processors are solved, but I'm experiencing still
> great problems
> on the performance of the actual preconditioner.
> I have an implementation of the BNN-algorithm in Matlab from a
> previous project
> which is performing very well (about 5 iterations vs. 200 for plain-
> cg) for a
> long linear elastic beam fixed at one end and loaded at the other end,
> discretized with solid cubic bricks (8 nodes, 24 DOF's). condition
> of the
> Matrix: 1.5e7
> I now modeled a similar beam in DIANA (a bit shorter, less elements
> due to
> restrictions of DIANA-preprocessor) and tried to solve with PETSc-
> solver.
> The condition of the Matrix is of the same magnitude: ~3e7 (smallest
> singular
> value: ~1e-3, largest sv: ~4e4), number of iterations for plain-cg
> seems
> reasonable (437), but for the preconditioned system I get completely
> unexpected
> values:
> condition: ~7e12 (smallest sv: ~1, largest sv: ~7e12) and therefore
> 612
> iterations for cg.
> The beam is divided in 4 subdomains. For more subdomains ksp ran out
> of
> iterations (Converged_Reason -3). I can imagine this is a problem of
> properly
> setting the null space, because only the first subdomain is touching
> the
> boundary, but I have no idea how to specify the null space. So far I
> didn't
> regard this issue at all.
> Do I have to define a function which calculates the weights of the
> interface
> DOF's and applies in a some way to create an orthonormal basis? How
> do I realize
> that? Is there anywhere an example?
> Cheers,
> ando
> /"\                               Grassl Andreas
> \ /    ASCII Ribbon Campaign      Uni Innsbruck Institut f. Mathematik
>  X      against HTML email        Technikerstr. 13 Zi 709
> / \                               +43 (0)512 507 6091
