MPICH error when using petsc-3.0.0-p4
Mon Apr 13 11:27:30 CDT 2009
And if v_ast() is used with PETSc - then it should be defined 'PetscScalar'
and then you use MPI_ISEND(....,MPIU_SCALAR,...)
Satish
On Mon, 13 Apr 2009, Barry Smith wrote:
>   Where is your implicit none that all sane programmers begin their Fortran
> subroutines with?
> On Apr 13, 2009, at 11:11 AM, Wee-Beng TAY wrote:
> > Hi Satish,
> > Compiling and building now worked without error. However, when I run, I get
> > the error:
> > 0 - MPI_ISEND : Datatype is MPI_TYPE_NULL
> > [0]  Aborting program !
> > [0] Aborting program!
> > Error 323, process 0, host GOTCHAMA-E73BB3:
> > The problem lies in this subroutine:
> > subroutine v_ast_row_copy
> > #include "finclude/petsc.h"
> > #include "finclude/petscvec.h"
> > #include "finclude/petscmat.h"
> > #include "finclude/petscksp.h"
> > #include "finclude/petscpc.h"
> > #include "finclude/petscsys.h"
> > !to copy data of jend row to others
> > integer :: inext,iprev,istatus(MPI_STATUS_SIZE),irecv1,ierr,isend1
> > inext = myid + 1
> > iprev = myid - 1
> > if (myid == num_procs - 1) inext = MPI_PROC_NULL
> > if (myid == 0) iprev = MPI_PROC_NULL
> > CALL
> > MPI_ISEND(v_ast(1,jend),size_x,MPI_REAL8,inext,1,MPI_COMM_WORLD,isend1,ierr)
> > CALL
> > MPI_IRECV(v_ast(1,jsta-1),size_x,MPI_REAL8,iprev,1,MPI_COMM_WORLD,irecv1,ierr)
> > CALL MPI_WAIT(isend1, istatus, ierr)
> > CALL MPI_WAIT(irecv1, istatus, ierr)
> > end subroutine v_ast_row_copy
> > I copied this subroutine from the RS6000 mpi manual and it used to work. I
> > wonder if this is a MPI or PETSc problem? Strange because I already specify
> > the type to be MPI_REAL8. However changing to MPI_REAL solves the problem.
> > If this is a MPI problem, then you can just ignore it. I'll check it in some
> > MPI forum.
> > Thank you very much and have a nice day!
> > Yours sincerely,
> > Wee-Beng Tay
> > Satish Balay wrote:
> > > Yes - all includes statements in both the sourcefiles should start
> > > with "finclude/..." [so that -Id:\cygwin\codes\petsc-3.0.0-p4 is not
> > > needed]
> > > And where you needed PETSC_AVOID_DECLARATIONS - you need to use the
> > > 'def.h' equivelent includes.. The def.h files have only the
> > > declarations [so the PETSC_AVOID_DECLARATIONS flag is no longer
> > > needed/used]. You need only the definitions in the datasection of
> > > 'module flux_area'. [All subroutines should use the regular includes]
> > > Satish
> > > On Mon, 13 Apr 2009, Wee-Beng TAY wrote:
> > > > Hi Satish,
> > > > I now used
> > > > for global.F and
> > > > #include "finclude/petscdef.h"
> > > > #include "finclude/petscvecdef.h"
> > > > #include "finclude/petscmatdef.h"
> > > > #include "finclude/petsckspdef.h"
> > > > #include "finclude/petscpcdef.h"
> > > > for flux_area.f90 and it's working now. Can you explain what's
> > > > happening? Is
> > > > this the correct way then?
> > > > Yours sincerely,
> > > > Wee-Beng Tay
> > > > Satish Balay wrote:
> > > > > 2 changes you have to make for 3.0.0
> > > > > 1. "include/finclude.. -> "finclude..."
> > > > > 2. PETSC_AVOID_DECLARATIONS should be removed - and use petscdef.h
> > > > > equivalnet files.
> > > > > i.e
> > > > > change:
> > > > > #define PETSC_AVOID_DECLARATIONS
> > > > > #include "include/finclude/petsc.h"
> > > > > #include "include/finclude/petscvec.h"
> > > > > #include "include/finclude/petscmat.h"
> > > > > #include "include/finclude/petscksp.h"
> > > > > #include "include/finclude/petscpc.h"
> > > > > #undef PETSC_AVOID_DECLARATIONS
> > > > > to:
> > > > > Satish
> > > > > On Sun, 12 Apr 2009, Wee-Beng TAY wrote:
> > > > > > Hi Satish,
> > > > > > I am now using the PETSc ex2f example. I tried "make ex2f" and
> > > > > > manage to
> > > > > > build
> > > > > > and run the file. Then I used the options as a reference for my
> > > > > > visual
> > > > > > fortran
> > > > > > and it worked.
> > > > > > The options are:
> > > > > > /compile_only /debug:full /include:"Debug/"
> > > > > > /include:"d:\cygwin\codes\petsc-3.0.0-p4\win32_mpi_debug\include"
> > > > > > /include:"d:\cygwin\codes\petsc-3.0.0-p4\include"
> > > > > > /include:"E:\cygwin\codes\MPICH\SDK\include" /nologo /threads
> > > > > > /warn:nofileopt
> > > > > > /module:"Debug/" /object:"Debug/" /pdbfile:"Debug/DF60.PDB"
> > > > > > /fpp:"/m"
> > > > > > and
> > > > > > ws2_32.lib kernel32.lib user32.lib gdi32.lib winspool.lib
> > > > > > comdlg32.lib
> > > > > > advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib
> > > > > > odbccp32.lib libpetscts.lib libpetscsnes.lib libpetscksp.lib
> > > > > > libpetscdm.lib
> > > > > > libpetscmat.lib libpetscvec.lib libpetsc.lib mpich.lib libfblas.lib
> > > > > > libflapack.lib /nologo /subsystem:console /incremental:yes
> > > > > > /pdb:"Debug/ex2f.pdb" /debug /machine:I386 /out:"Debug/ex2f.exe"
> > > > > > /pdbtype:sept
> > > > > > /libpath:"d:\cygwin\codes\petsc-3.0.0-p4\win32_mpi_debug\lib"
> > > > > > /libpath:"E:\cygwin\codes\MPICH\SDK\lib"
> > > > > > Now I add my own file called global.F and tried to compile, using
> > > > > > the same
> > > > > > options.But now it failed. The error is:
> > > > > > --------------------Configuration: ex2f - Win32
> > > > > > Debug--------------------
> > > > > > Compiling Fortran...
> > > > > > D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F:
> > > > > >  7: #include "include/finclude/petsc.h"
> > > > > > ** error  on line 7 in D:\cygwin\codes\pets: cannot find file
> > > > > > specified
> > > > > >   in include directive.
> > > > > >  8: #include "include/finclude/petscvec.h"
> > > > > > ** error  on line 8 in D:\cygwin\codes\pets: cannot find file
> > > > > > specified
> > > > > >  9: #include "include/finclude/petscmat.h"
> > > > > > ** error  on line 9 in D:\cygwin\codes\pets: cannot find file
> > > > > > specified
> > > > > > 10: #include "include/finclude/petscksp.h"
> > > > > > ** error  on line 10 in D:\cygwin\codes\pets: cannot find file
> > > > > >   specified in include directive.
> > > > > > 11: #include "include/finclude/petscpc.h"
> > > > > > ** error  on line 11 in D:\cygwin\codes\pets: cannot find file
> > > > > > 12: #include "include/finclude/petscsys.h"
> > > > > > ** error  on line 12 in D:\cygwin\codes\pets: cannot find file
> > > > > > 97: #include "include/finclude/petsc.h"
> > > > > > ** error  on line 97 in D:\cygwin\codes\pets: cannot find file
> > > > > > 98: #include "include/finclude/petscvec.h"
> > > > > > ** error  on line 98 in D:\cygwin\codes\pets: cannot find file
> > > > > > 99: #include "include/finclude/petscmat.h"
> > > > > > ** error  on line 99 in D:\cygwin\codes\pets: cannot find file
> > > > > > 100: #include "include/finclude/petscksp.h"
> > > > > > ** error  on line 100 in D:\cygwin\codes\pets: cannot find file
> > > > > > 101: #include "include/finclude/petscpc.h"
> > > > > > ** error  on line 101 in D:\cygwin\codes\pets: cannot find file
> > > > > > 102: #include "include/finclude/petscsys.h"
> > > > > > ** error  on line 102 in D:\cygwin\codes\pets: cannot find file
> > > > > > global.i
> > > > > > D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(65)
> > > > > > Error:
> > > > > > Syntax error, found ',' when expecting one of: ( : % . = =>
> > > > > > Vec    xx,b_rhs,xx_uv,b_rhs_uv
> > > > > > D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(67)
> > > > > > Error:
> > > > > > Mat    A_mat,A_mat_uv    !  /* sparse matrix */
> > > > > > D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(69)
> > > > > > Error:
> > > > > > KSP   ksp,ksp_uv    !/* linear solver context */
> > > > > > D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(71)
> > > > > > Error:
> > > > > > PC pc,pc_uv
> > > > > > D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(73)
> > > > > > Error:
> > > > > > Syntax error, found END-OF-STATEMENT when expecting one of: ( : % .
> > > > > > PCType      ptype
> > > > > > D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(75)
> > > > > > Error:
> > > > > > KSPType  ksptype....
> > > > > > I can get it to compile if I use :
> > > > > > Debug/;d:\cygwin\codes\petsc-3.0.0-p4;d:\cygwin\codes\petsc-3.0.0-p4\include;d:\cygwin\codes\petsc-3.0.0-p4\win32_mpi_debug\include;E:\cygwin\codes\MPICH\SDK\include
> > > > > > Compared to the original one above which is:
> > > > > > Debug/;d:\cygwin\codes\petsc-3.0.0-p4\win32_mpi_debug\include;d:\cygwin\codes\petsc-3.0.0-p4\include;E:\cygwin\codes\MPICH\SDK\include
> > > > > > Hence, there is an additional "d:\cygwin\codes\petsc-3.0.0-p4"
> > > > > > I have attached my global.F. I wonder if this is the cause of the
> > > > > > MPICH
> > > > > > error.
> > > > > > Currently, I have removed all other f90 files, except for global.F
> > > > > > and
> > > > > > flux_area.f90. It's when I 'm compiling flux_area.f90 that I got the
> > > > > > MPI
> > > > > > error
> > > > > > stated below. I got the same error if I compile under cygwin using
> > > > > > the
> > > > > > same
> > > > > > parameters.
> > > > > > Hope you can help.
> > > > > > Yours sincerely,
> > > > > > Wee-Beng Tay
> > > > > > Satish Balay wrote:
> > > > > > > Do you get these errors with PETSc f90 examples?
> > > > > > > what 'USE statement' do you have in your code?
> > > > > > > I guess you'll have to check your code to see how you are using
> > > > > > > f90
> > > > > > > modules/includes.
> > > > > > > If you can get a minimal compileable code that can reproduce this
> > > > > > > error - send us the code so that we can reproduce the issue
> > > > > > > Satish
> > > > > > > On Thu, 9 Apr 2009, Wee-Beng TAY wrote:
> > > > > > > > Hi,
> > > > > > > > I just built petsc-3.0.0-p4 with mpich and after that, I
> > > > > > > > reinstalled
> > > > > > > > my
> > > > > > > > windows xp and installed mpich in the same directory. I'm using
> > > > > > > > CVF
> > > > > > > > Now, I found that when I'm trying to compile my code, I got the
> > > > > > > > error:
> > > > > > > > :\cygwin\codes\MPICH\SDK\include\mpif.h(105) : Error: The
> > > > > > > > attributes
> > > > > > > > of
> > > > > > > > this
> > > > > > > > name conflict with those made accessible by a USE statement.
> > > > > > > > [MPI_STATUS_SIZE]
> > > > > > > >    INTEGER MPI_STATUS_IGNORE(MPI_STATUS_SIZE)
> > > > > > > > E:\cygwin\codes\MPICH\SDK\include\mpif.h(106) : Error: The
> > > > > > > > attributes
> > > > > > > > of
> > > > > > > > this
> > > > > > > > [MPI_STATUS_SIZE]
> > > > > > > >    INTEGER MPI_STATUSES_IGNORE(MPI_STATUS_SIZE)
> > > > > > > > E:\cygwin\codes\petsc-3.0.0-p4\include/finclude/petsc.h(154) :
> > > > > > > > Error:
> > > > > > > > The
> > > > > > > > attributes of this name conflict with those made accessible by a
> > > > > > > > USE
> > > > > > > > statement.   [MPI_DOUBLE_PRECISION]
> > > > > > > >    parameter(MPIU_SCALAR = MPI_DOUBLE_PRECISION)
> > > > > > > > Error executing df.exe.
> > > > > > > > flux_area.obj - 3 error(s), 0 warning(s)
> > > > > > > > My include option is :
> > > > > > > > Debug/;$(PETSC_DIR);$(PETSC_DIR)\$(PETSC_ARCH)\;$(PETSC_DIR)\$(PETSC_ARCH)\include;$(PETSC_DIR)\include;E:\cygwin\codes\MPICH\SDK\include
> > > > > > > > Interestingly, when I change my PETSC_DIR to petsc-dev, which
> > > > > > > > correspond
> > > > > > > > to an
> > > > > > > > old build of petsc-2.3.3-p13, there is no problem.
> > > > > > > > May I know what's wrong? Btw, I've converted my mpif.h from
> > > > > > > > using "C"
> > > > > > > > as
> > > > > > > > comments to "!".
> > > > > > > > Yours sincerely,
> > > > > > > > Wee-Beng Tay
