MPICH error when using petsc-3.0.0-p4
Wee-Beng TAY zonexo at gmail.com
Mon Apr 13 19:49:02 CDT 2009
Hi Satish and Barry,
It worked! Btw, this is only one of the subroutines in my module file.
Hence, my "implicit none" is found at the top of the module file. Thanks
for the reminder though, Barry.
Thank you very much and have a nice day!
Yours sincerely,
Wee-Beng Tay
Satish Balay wrote:
> And if v_ast() is used with PETSc - then it should be defined 'PetscScalar'
> and then you use MPI_ISEND(....,MPIU_SCALAR,...)
> Satish
> On Mon, 13 Apr 2009, Barry Smith wrote:
>>   Where is your implicit none that all sane programmers begin their Fortran
>> subroutines with?
>> On Apr 13, 2009, at 11:11 AM, Wee-Beng TAY wrote:
>>> Hi Satish,
>>> Compiling and building now worked without error. However, when I run, I get
>>> the error:
>>> 0 - MPI_ISEND : Datatype is MPI_TYPE_NULL
>>> [0]  Aborting program !
>>> [0] Aborting program!
>>> Error 323, process 0, host GOTCHAMA-E73BB3:
>>> The problem lies in this subroutine:
>>> subroutine v_ast_row_copy
>>> #include "finclude/petsc.h"
>>> #include "finclude/petscvec.h"
>>> #include "finclude/petscmat.h"
>>> #include "finclude/petscksp.h"
>>> #include "finclude/petscpc.h"
>>> #include "finclude/petscsys.h"
>>> !to copy data of jend row to others
>>> integer :: inext,iprev,istatus(MPI_STATUS_SIZE),irecv1,ierr,isend1
>>> inext = myid + 1
>>> iprev = myid - 1
>>> if (myid == num_procs - 1) inext = MPI_PROC_NULL
>>> if (myid == 0) iprev = MPI_PROC_NULL
>>> CALL
>>> MPI_ISEND(v_ast(1,jend),size_x,MPI_REAL8,inext,1,MPI_COMM_WORLD,isend1,ierr)
>>> CALL
>>> MPI_IRECV(v_ast(1,jsta-1),size_x,MPI_REAL8,iprev,1,MPI_COMM_WORLD,irecv1,ierr)
>>> CALL MPI_WAIT(isend1, istatus, ierr)
>>> CALL MPI_WAIT(irecv1, istatus, ierr)
>>> end subroutine v_ast_row_copy
>>> I copied this subroutine from the RS6000 mpi manual and it used to work. I
>>> wonder if this is a MPI or PETSc problem? Strange because I already specify
>>> the type to be MPI_REAL8. However changing to MPI_REAL solves the problem.
>>> If this is a MPI problem, then you can just ignore it. I'll check it in some
>>> MPI forum.
>>> Yours sincerely,
>>> Wee-Beng Tay
>>> Satish Balay wrote:
>>>> Yes - all includes statements in both the sourcefiles should start
>>>> with "finclude/..." [so that -Id:\cygwin\codes\petsc-3.0.0-p4 is not
>>>> needed]
>>>> And where you needed PETSC_AVOID_DECLARATIONS - you need to use the
>>>> 'def.h' equivelent includes.. The def.h files have only the
>>>> declarations [so the PETSC_AVOID_DECLARATIONS flag is no longer
>>>> needed/used]. You need only the definitions in the datasection of
>>>> 'module flux_area'. [All subroutines should use the regular includes]
>>>> Satish
>>>> On Mon, 13 Apr 2009, Wee-Beng TAY wrote:
>>>>> Hi Satish,
>>>>> I now used
>>>>> for global.F and
>>>>> #include "finclude/petscdef.h"
>>>>> #include "finclude/petscvecdef.h"
>>>>> #include "finclude/petscmatdef.h"
>>>>> #include "finclude/petsckspdef.h"
>>>>> #include "finclude/petscpcdef.h"
>>>>> for flux_area.f90 and it's working now. Can you explain what's
>>>>> happening? Is
>>>>> this the correct way then?
>>>>> Yours sincerely,
>>>>> Wee-Beng Tay
>>>>> Satish Balay wrote:
>>>>>> 2 changes you have to make for 3.0.0
>>>>>> 1. "include/finclude.. -> "finclude..."
>>>>>> 2. PETSC_AVOID_DECLARATIONS should be removed - and use petscdef.h
>>>>>> equivalnet files.
>>>>>> i.e
>>>>>> change:
>>>>>> #define PETSC_AVOID_DECLARATIONS
>>>>>> #include "include/finclude/petsc.h"
>>>>>> #include "include/finclude/petscvec.h"
>>>>>> #include "include/finclude/petscmat.h"
>>>>>> #include "include/finclude/petscksp.h"
>>>>>> #include "include/finclude/petscpc.h"
>>>>>> #undef PETSC_AVOID_DECLARATIONS
>>>>>> to:
>>>>>> Satish
>>>>>> On Sun, 12 Apr 2009, Wee-Beng TAY wrote:
>>>>>>> Hi Satish,
>>>>>>> I am now using the PETSc ex2f example. I tried "make ex2f" and
>>>>>>> manage to
>>>>>>> build
>>>>>>> and run the file. Then I used the options as a reference for my
>>>>>>> visual
>>>>>>> fortran
>>>>>>> and it worked.
>>>>>>> The options are:
>>>>>>> /compile_only /debug:full /include:"Debug/"
>>>>>>> /include:"d:\cygwin\codes\petsc-3.0.0-p4\win32_mpi_debug\include"
>>>>>>> /include:"d:\cygwin\codes\petsc-3.0.0-p4\include"
>>>>>>> /include:"E:\cygwin\codes\MPICH\SDK\include" /nologo /threads
>>>>>>> /warn:nofileopt
>>>>>>> /module:"Debug/" /object:"Debug/" /pdbfile:"Debug/DF60.PDB"
>>>>>>> /fpp:"/m"
>>>>>>> and
>>>>>>> ws2_32.lib kernel32.lib user32.lib gdi32.lib winspool.lib
>>>>>>> comdlg32.lib
>>>>>>> advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib
>>>>>>> odbccp32.lib libpetscts.lib libpetscsnes.lib libpetscksp.lib
>>>>>>> libpetscdm.lib
>>>>>>> libpetscmat.lib libpetscvec.lib libpetsc.lib mpich.lib libfblas.lib
>>>>>>> libflapack.lib /nologo /subsystem:console /incremental:yes
>>>>>>> /pdb:"Debug/ex2f.pdb" /debug /machine:I386 /out:"Debug/ex2f.exe"
>>>>>>> /pdbtype:sept
>>>>>>> /libpath:"d:\cygwin\codes\petsc-3.0.0-p4\win32_mpi_debug\lib"
>>>>>>> /libpath:"E:\cygwin\codes\MPICH\SDK\lib"
>>>>>>> Now I add my own file called global.F and tried to compile, using
>>>>>>> the same
>>>>>>> options.But now it failed. The error is:
>>>>>>> --------------------Configuration: ex2f - Win32
>>>>>>> Debug--------------------
>>>>>>> Compiling Fortran...
>>>>>>> D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F:
>>>>>>>  7: #include "include/finclude/petsc.h"
>>>>>>> ** error  on line 7 in D:\cygwin\codes\pets: cannot find file
>>>>>>> specified
>>>>>>>   in include directive.
>>>>>>>  8: #include "include/finclude/petscvec.h"
>>>>>>> ** error  on line 8 in D:\cygwin\codes\pets: cannot find file
>>>>>>> specified
>>>>>>>  9: #include "include/finclude/petscmat.h"
>>>>>>> ** error  on line 9 in D:\cygwin\codes\pets: cannot find file
>>>>>>> specified
>>>>>>> 10: #include "include/finclude/petscksp.h"
>>>>>>> ** error  on line 10 in D:\cygwin\codes\pets: cannot find file
>>>>>>>   specified in include directive.
>>>>>>> 11: #include "include/finclude/petscpc.h"
>>>>>>> ** error  on line 11 in D:\cygwin\codes\pets: cannot find file
>>>>>>> 12: #include "include/finclude/petscsys.h"
>>>>>>> ** error  on line 12 in D:\cygwin\codes\pets: cannot find file
>>>>>>> 97: #include "include/finclude/petsc.h"
>>>>>>> ** error  on line 97 in D:\cygwin\codes\pets: cannot find file
>>>>>>> 98: #include "include/finclude/petscvec.h"
>>>>>>> ** error  on line 98 in D:\cygwin\codes\pets: cannot find file
>>>>>>> 99: #include "include/finclude/petscmat.h"
>>>>>>> ** error  on line 99 in D:\cygwin\codes\pets: cannot find file
>>>>>>> 100: #include "include/finclude/petscksp.h"
>>>>>>> ** error  on line 100 in D:\cygwin\codes\pets: cannot find file
>>>>>>> 101: #include "include/finclude/petscpc.h"
>>>>>>> ** error  on line 101 in D:\cygwin\codes\pets: cannot find file
>>>>>>> 102: #include "include/finclude/petscsys.h"
>>>>>>> ** error  on line 102 in D:\cygwin\codes\pets: cannot find file
>>>>>>> global.i
>>>>>>> D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(65)
>>>>>>> Error:
>>>>>>> Syntax error, found ',' when expecting one of: ( : % . = =>
>>>>>>> Vec    xx,b_rhs,xx_uv,b_rhs_uv
>>>>>>> D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(67)
>>>>>>> Error:
>>>>>>> Mat    A_mat,A_mat_uv    !  /* sparse matrix */
>>>>>>> D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(69)
>>>>>>> Error:
>>>>>>> KSP   ksp,ksp_uv    !/* linear solver context */
>>>>>>> D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(71)
>>>>>>> Error:
>>>>>>> PC pc,pc_uv
>>>>>>> D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(73)
>>>>>>> Error:
>>>>>>> Syntax error, found END-OF-STATEMENT when expecting one of: ( : % .
>>>>>>> PCType      ptype
>>>>>>> D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F(75)
>>>>>>> Error:
>>>>>>> KSPType  ksptype....
>>>>>>> I can get it to compile if I use :
>>>>>>> Debug/;d:\cygwin\codes\petsc-3.0.0-p4;d:\cygwin\codes\petsc-3.0.0-p4\include;d:\cygwin\codes\petsc-3.0.0-p4\win32_mpi_debug\include;E:\cygwin\codes\MPICH\SDK\include
>>>>>>> Compared to the original one above which is:
>>>>>>> Debug/;d:\cygwin\codes\petsc-3.0.0-p4\win32_mpi_debug\include;d:\cygwin\codes\petsc-3.0.0-p4\include;E:\cygwin\codes\MPICH\SDK\include
>>>>>>> Hence, there is an additional "d:\cygwin\codes\petsc-3.0.0-p4"
>>>>>>> I have attached my global.F. I wonder if this is the cause of the
>>>>>>> MPICH
>>>>>>> error.
>>>>>>> Currently, I have removed all other f90 files, except for global.F
>>>>>>> and
>>>>>>> flux_area.f90. It's when I 'm compiling flux_area.f90 that I got the
>>>>>>> MPI
>>>>>>> error
>>>>>>> stated below. I got the same error if I compile under cygwin using
>>>>>>> the
>>>>>>> same
>>>>>>> parameters.
>>>>>>> Hope you can help.
>>>>>>> Yours sincerely,
>>>>>>> Wee-Beng Tay
>>>>>>> Satish Balay wrote:
>>>>>>>> Do you get these errors with PETSc f90 examples?
>>>>>>>> what 'USE statement' do you have in your code?
>>>>>>>> I guess you'll have to check your code to see how you are using
>>>>>>>> f90
>>>>>>>> modules/includes.
>>>>>>>> If you can get a minimal compileable code that can reproduce this
>>>>>>>> error - send us the code so that we can reproduce the issue
>>>>>>>> Satish
>>>>>>>> On Thu, 9 Apr 2009, Wee-Beng TAY wrote:
>>>>>>>>> Hi,
>>>>>>>>> I just built petsc-3.0.0-p4 with mpich and after that, I
>>>>>>>>> reinstalled
>>>>>>>>> my
>>>>>>>>> windows xp and installed mpich in the same directory. I'm using
>>>>>>>>> CVF
>>>>>>>>> Now, I found that when I'm trying to compile my code, I got the
>>>>>>>>> error:
>>>>>>>>> :\cygwin\codes\MPICH\SDK\include\mpif.h(105) : Error: The
>>>>>>>>> attributes
>>>>>>>>> of
>>>>>>>>> this
>>>>>>>>> name conflict with those made accessible by a USE statement.
>>>>>>>>> [MPI_STATUS_SIZE]
>>>>>>>>>    INTEGER MPI_STATUS_IGNORE(MPI_STATUS_SIZE)
>>>>>>>>> E:\cygwin\codes\MPICH\SDK\include\mpif.h(106) : Error: The
>>>>>>>>> attributes
>>>>>>>>> of
>>>>>>>>> this
>>>>>>>>> [MPI_STATUS_SIZE]
>>>>>>>>>    INTEGER MPI_STATUSES_IGNORE(MPI_STATUS_SIZE)
>>>>>>>>> E:\cygwin\codes\petsc-3.0.0-p4\include/finclude/petsc.h(154) :
>>>>>>>>> Error:
>>>>>>>>> The
>>>>>>>>> attributes of this name conflict with those made accessible by a
>>>>>>>>> USE
>>>>>>>>> statement.   [MPI_DOUBLE_PRECISION]
>>>>>>>>>    parameter(MPIU_SCALAR = MPI_DOUBLE_PRECISION)
>>>>>>>>> Error executing df.exe.
>>>>>>>>> flux_area.obj - 3 error(s), 0 warning(s)
>>>>>>>>> My include option is :
>>>>>>>>> Debug/;$(PETSC_DIR);$(PETSC_DIR)\$(PETSC_ARCH)\;$(PETSC_DIR)\$(PETSC_ARCH)\include;$(PETSC_DIR)\include;E:\cygwin\codes\MPICH\SDK\include
>>>>>>>>> Interestingly, when I change my PETSC_DIR to petsc-dev, which
>>>>>>>>> correspond
>>>>>>>>> to an
>>>>>>>>> old build of petsc-2.3.3-p13, there is no problem.
>>>>>>>>> May I know what's wrong? Btw, I've converted my mpif.h from
>>>>>>>>> using "C"
>>>>>>>>> as
>>>>>>>>> comments to "!".
>>>>>>>>> Yours sincerely,
>>>>>>>>> Wee-Beng Tay
