MPICH error when using petsc-3.0.0-p4
Mon Apr 13 11:21:29 CDT 2009
    Where is your implicit none that all sane programmers begin their
Fortran subroutines with?
On Apr 13, 2009, at 11:11 AM, Wee-Beng TAY wrote:
> Hi Satish,
> Compiling and building now worked without error. However, when I
> run, I get the error:
> 0 - MPI_ISEND : Datatype is MPI_TYPE_NULL
> [0]  Aborting program !
> [0] Aborting program!
> Error 323, process 0, host GOTCHAMA-E73BB3:
> The problem lies in this subroutine:
> subroutine v_ast_row_copy
> #include "finclude/petsc.h"
> #include "finclude/petscvec.h"
> #include "finclude/petscmat.h"
> #include "finclude/petscksp.h"
> #include "finclude/petscpc.h"
> #include "finclude/petscsys.h"
> !to copy data of jend row to others
> integer :: inext,iprev,istatus(MPI_STATUS_SIZE),irecv1,ierr,isend1
> inext = myid + 1
> iprev = myid - 1
> if (myid == num_procs - 1) inext = MPI_PROC_NULL
> if (myid == 0) iprev = MPI_PROC_NULL
> CALL MPI_ISEND(v_ast(1,jend),size_x,MPI_REAL8,inext,
> 1,MPI_COMM_WORLD,isend1,ierr)
> CALL MPI_IRECV(v_ast(1,jsta-1),size_x,MPI_REAL8,iprev,
> 1,MPI_COMM_WORLD,irecv1,ierr)
> CALL MPI_WAIT(isend1, istatus, ierr)
> CALL MPI_WAIT(irecv1, istatus, ierr)
> end subroutine v_ast_row_copy
> I copied this subroutine from the RS6000 mpi manual and it used to
> work. I wonder if this is a MPI or PETSc problem? Strange because I
> already specify the type to be MPI_REAL8. However changing to
> MPI_REAL solves the problem.
> If this is a MPI problem, then you can just ignore it. I'll check it
> in some MPI forum.
> Thank you very much and have a nice day!
> Yours sincerely,
> Wee-Beng Tay
> Satish Balay wrote:
>> Yes - all includes statements in both the sourcefiles should start
>> with "finclude/..." [so that -Id:\cygwin\codes\petsc-3.0.0-p4 is not
>> needed]
>> And where you needed PETSC_AVOID_DECLARATIONS - you need to use the
>> 'def.h' equivelent includes.. The def.h files have only the
>> declarations [so the PETSC_AVOID_DECLARATIONS flag is no longer
>> needed/used]. You need only the definitions in the datasection of
>> 'module flux_area'. [All subroutines should use the regular includes]
>> Satish
>> On Mon, 13 Apr 2009, Wee-Beng TAY wrote:
>>> Hi Satish,
>>> I now used
>>> for global.F and
>>> #include "finclude/petscdef.h"
>>> #include "finclude/petscvecdef.h"
>>> #include "finclude/petscmatdef.h"
>>> #include "finclude/petsckspdef.h"
>>> #include "finclude/petscpcdef.h"
>>> for flux_area.f90 and it's working now. Can you explain what's
>>> happening? Is
>>> this the correct way then?
>>> Yours sincerely,
>>> Wee-Beng Tay
>>> Satish Balay wrote:
>>>> 2 changes you have to make for 3.0.0
>>>> 1. "include/finclude.. -> "finclude..."
>>>> 2. PETSC_AVOID_DECLARATIONS should be removed - and use petscdef.h
>>>> equivalnet files.
>>>> i.e
>>>> change:
>>>> #define PETSC_AVOID_DECLARATIONS
>>>> #include "include/finclude/petsc.h"
>>>> #include "include/finclude/petscvec.h"
>>>> #include "include/finclude/petscmat.h"
>>>> #include "include/finclude/petscksp.h"
>>>> #include "include/finclude/petscpc.h"
>>>> #undef PETSC_AVOID_DECLARATIONS
>>>> to:
>>>> Satish
>>>> On Sun, 12 Apr 2009, Wee-Beng TAY wrote:
>>>>> Hi Satish,
>>>>> I am now using the PETSc ex2f example. I tried "make ex2f" and
>>>>> manage to
>>>>> build
>>>>> and run the file. Then I used the options as a reference for my
>>>>> visual
>>>>> fortran
>>>>> and it worked.
>>>>> The options are:
>>>>> /compile_only /debug:full /include:"Debug/"
>>>>> /include:"d:\cygwin\codes\petsc-3.0.0-p4\win32_mpi_debug\include"
>>>>> /include:"d:\cygwin\codes\petsc-3.0.0-p4\include"
>>>>> /include:"E:\cygwin\codes\MPICH\SDK\include" /nologo /threads
>>>>> /warn:nofileopt
>>>>> /module:"Debug/" /object:"Debug/" /pdbfile:"Debug/DF60.PDB" /
>>>>> fpp:"/m"
>>>>> and
>>>>> ws2_32.lib kernel32.lib user32.lib gdi32.lib winspool.lib
>>>>> comdlg32.lib
>>>>> advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib
>>>>> odbc32.lib
>>>>> odbccp32.lib libpetscts.lib libpetscsnes.lib libpetscksp.lib
>>>>> libpetscdm.lib
>>>>> libpetscmat.lib libpetscvec.lib libpetsc.lib mpich.lib
>>>>> libfblas.lib
>>>>> libflapack.lib /nologo /subsystem:console /incremental:yes
>>>>> /pdb:"Debug/ex2f.pdb" /debug /machine:I386 /out:"Debug/ex2f.exe"
>>>>> /pdbtype:sept
>>>>> /libpath:"d:\cygwin\codes\petsc-3.0.0-p4\win32_mpi_debug\lib"
>>>>> /libpath:"E:\cygwin\codes\MPICH\SDK\lib"
>>>>> Now I add my own file called global.F and tried to compile,
>>>>> using the same
>>>>> options.But now it failed. The error is:
>>>>> --------------------Configuration: ex2f - Win32
>>>>> Debug--------------------
>>>>> Compiling Fortran...
>>>>> D:\cygwin\codes\petsc-3.0.0-p4\projects\fortran\ksp\ex2f\global.F:
>>>>>   7: #include "include/finclude/petsc.h"
>>>>> ** error  on line 7 in D:\cygwin\codes\pets: cannot find file
>>>>> specified
>>>>>    in include directive.
>>>>>   8: #include "include/finclude/petscvec.h"
>>>>> ** error  on line 8 in D:\cygwin\codes\pets: cannot find file
>>>>> specified
>>>>>   9: #include "include/finclude/petscmat.h"
>>>>> ** error  on line 9 in D:\cygwin\codes\pets: cannot find file
>>>>> specified
>>>>>  10: #include "include/finclude/petscksp.h"
>>>>> ** error  on line 10 in D:\cygwin\codes\pets: cannot find file
>>>>>    specified in include directive.
>>>>>  11: #include "include/finclude/petscpc.h"
>>>>> ** error  on line 11 in D:\cygwin\codes\pets: cannot find file
>>>>>  12: #include "include/finclude/petscsys.h"
>>>>> ** error  on line 12 in D:\cygwin\codes\pets: cannot find file
>>>>>  97: #include "include/finclude/petsc.h"
>>>>> ** error  on line 97 in D:\cygwin\codes\pets: cannot find file
>>>>>  98: #include "include/finclude/petscvec.h"
>>>>> ** error  on line 98 in D:\cygwin\codes\pets: cannot find file
>>>>>  99: #include "include/finclude/petscmat.h"
>>>>> ** error  on line 99 in D:\cygwin\codes\pets: cannot find file
>>>>> 100: #include "include/finclude/petscksp.h"
>>>>> ** error  on line 100 in D:\cygwin\codes\pets: cannot find file
>>>>> 101: #include "include/finclude/petscpc.h"
>>>>> ** error  on line 101 in D:\cygwin\codes\pets: cannot find file
>>>>> 102: #include "include/finclude/petscsys.h"
>>>>> ** error  on line 102 in D:\cygwin\codes\pets: cannot find file
>>>>> global.i
>>>>> \global.F(65) :
>>>>> Error:
>>>>> Syntax error, found ',' when expecting one of: ( : % . = =>
>>>>> Vec    xx,b_rhs,xx_uv,b_rhs_uv
>>>>> \global.F(67) :
>>>>> Error:
>>>>> Mat    A_mat,A_mat_uv    !  /* sparse matrix */
>>>>> \global.F(69) :
>>>>> Error:
>>>>> KSP   ksp,ksp_uv    !/* linear solver context */
>>>>> \global.F(71) :
>>>>> Error:
>>>>> PC pc,pc_uv
>>>>> \global.F(73) :
>>>>> Error:
>>>>> Syntax error, found END-OF-STATEMENT when expecting one of: ( :
>>>>> PCType      ptype
>>>>> \global.F(75) :
>>>>> Error:
>>>>> KSPType  ksptype....
>>>>> I can get it to compile if I use :
>>>>> Debug/;d:\cygwin\codes\petsc-3.0.0-p4;d:\cygwin\codes
>>>>> \petsc-3.0.0-p4\include;d:\cygwin\codes\petsc-3.0.0-
>>>>> p4\win32_mpi_debug\include;E:\cygwin\codes\MPICH\SDK\include
>>>>> Compared to the original one above which is:
>>>>> Debug/;d:\cygwin\codes\petsc-3.0.0-p4\win32_mpi_debug\include;d:
>>>>> \cygwin\codes\petsc-3.0.0-p4\include;E:\cygwin\codes\MPICH\SDK
>>>>> \include
>>>>> Hence, there is an additional "d:\cygwin\codes\petsc-3.0.0-p4"
>>>>> I have attached my global.F. I wonder if this is the cause of
>>>>> the MPICH
>>>>> error.
>>>>> Currently, I have removed all other f90 files, except for
>>>>> global.F and
>>>>> flux_area.f90. It's when I 'm compiling flux_area.f90 that I got
>>>>> the MPI
>>>>> error
>>>>> stated below. I got the same error if I compile under cygwin
>>>>> using the
>>>>> same
>>>>> parameters.
>>>>> Hope you can help.
>>>>> Yours sincerely,
>>>>> Wee-Beng Tay
>>>>> Satish Balay wrote:
>>>>>> Do you get these errors with PETSc f90 examples?
>>>>>> what 'USE statement' do you have in your code?
>>>>>> I guess you'll have to check your code to see how you are using
>>>>>> f90
>>>>>> modules/includes.
>>>>>> If you can get a minimal compileable code that can reproduce this
>>>>>> error - send us the code so that we can reproduce the issue
>>>>>> Satish
>>>>>> On Thu, 9 Apr 2009, Wee-Beng TAY wrote:
>>>>>>> Hi,
>>>>>>> I just built petsc-3.0.0-p4 with mpich and after that, I
>>>>>>> reinstalled
>>>>>>> my
>>>>>>> windows xp and installed mpich in the same directory. I'm
>>>>>>> using CVF
>>>>>>> Now, I found that when I'm trying to compile my code, I got
>>>>>>> the error:
>>>>>>> :\cygwin\codes\MPICH\SDK\include\mpif.h(105) : Error: The
>>>>>>> attributes
>>>>>>> of
>>>>>>> this
>>>>>>> name conflict with those made accessible by a USE statement.
>>>>>>> [MPI_STATUS_SIZE]
>>>>>>>     INTEGER MPI_STATUS_IGNORE(MPI_STATUS_SIZE)
>>>>>>> E:\cygwin\codes\MPICH\SDK\include\mpif.h(106) : Error: The
>>>>>>> attributes
>>>>>>> of
>>>>>>> this
>>>>>>> [MPI_STATUS_SIZE]
>>>>>>>     INTEGER MPI_STATUSES_IGNORE(MPI_STATUS_SIZE)
>>>>>>> E:\cygwin\codes\petsc-3.0.0-p4\include/finclude/petsc.h(154) :
>>>>>>> Error:
>>>>>>> The
>>>>>>> attributes of this name conflict with those made accessible by
>>>>>>> a USE
>>>>>>> statement.   [MPI_DOUBLE_PRECISION]
>>>>>>>     parameter(MPIU_SCALAR = MPI_DOUBLE_PRECISION)
>>>>>>> Error executing df.exe.
>>>>>>> flux_area.obj - 3 error(s), 0 warning(s)
>>>>>>> My include option is :
>>>>>>> Debug/;$(PETSC_DIR);$(PETSC_DIR)\$(PETSC_ARCH)\;$(PETSC_DIR)\$
>>>>>>> (PETSC_ARCH)\include;$(PETSC_DIR)\include;E:\cygwin\codes\MPICH
>>>>>>> \SDK\include
>>>>>>> Interestingly, when I change my PETSC_DIR to petsc-dev, which
>>>>>>> correspond
>>>>>>> to an
>>>>>>> old build of petsc-2.3.3-p13, there is no problem.
>>>>>>> May I know what's wrong? Btw, I've converted my mpif.h from
>>>>>>> using "C"
>>>>>>> as
>>>>>>> comments to "!".
>>>>>>> Yours sincerely,
>>>>>>> Wee-Beng Tay
