linear solver for complex matrix
zhifeng sheng z.sheng at ewi.tudelft.nl
Mon Oct 27 10:11:37 CDT 2008
Dear all
It looks like something strange is going on for my Petsc (which was
built with '--with-scalar-type=complex'.):
1) I got a complex system of equation, with I can solve with CG+SOR .
But when I try to use BICGS+SOR to solve it, it never converges.
2) I noticed that the transpose function for complex matrices was not
what I was looking for. It really computes the transpose instead of the
conjugate transpose which is the "right transpose" for complex matrix.
For some linear solvers, e.g. BICG, BCGS, need to compute the transpose
of real system matrix (to multiply it with a vector),  while they need
to compute the conjugate transpose for complex system matrices.
So I am wondering whether BICGS+SOR did not converge for my complex
matrix because of a bad A^Tx used internally in these linear solvers.
Such problem does not exist for CG+SOR, therefore, CG+SOR converged.
PS: I sent some emails about this problem before, but I guess I did not
make myself clear :o
Thanks a lot
Best regards
Zhifeng Sheng
Hong Zhang wrote:
> Zhifeng,
> Petsc's linear solvers, including
> the external packages (e.g., superlu, mumps, and spooles)
> all support complex precision,
> simply configure petsc library with
>> How can I make the other linear solvers work for complex system? I
>> think if only I can make the transpose function a little different
>> then they should work. but I don't know where I should start.
>> Did anyone have similar problem with the linear solvers for complex
>> system before (the linear solver for complex system needs conjugate
>> transpose)? and how could you solve it?
> Why do you need conjugate transpose for using petsc solver?
> Do you develop your onw solver for Hermitian matrix?
> We do not have some basic matrix operations for Hermitian matrix yet,
> e.g., MatMult_Hermitian() when only half of the matrix entries
> are stored. You need implement this operation for your onw
> solver.
> If you use petsc AIJ matrix format, all complex linear solvers
> should work. Storing half of entries is not as efficient
> as entire matrix when you have sufficient memory space.
> Hong
>> Thanks a lot
>> Best regards
>> Zhifeng Sheng
