Problem with MatMatMultTranspose (con'd)
Wed Oct 22 09:21:44 CDT 2008
On Oct 22, 2008, at 9:15 AM, zhifeng sheng wrote:
> Dear all
> suppose I have a complex matrix (Hermitian positive definite) to
> solve, which KSP solver(s) can support solving it?
> PS: for this moment, I don't need to take into account that the
> matrix is hermitian.
KSPCG and use KSPCGSetType(ksp,KSP_CG_HERMITIAN )
> By the way, if I really need conjugate transpose function for
> complex matrices, must I implement it myself?
yes
> (I mean, is there any function that I can make use of?)
> Thanks
> Best regards
> Zhifeng
> Barry Smith wrote:
>>   There is only support for CG with Hermitian transpose,
>> ksp_cg_type symmetric or hermitian, KSPCGSetType()
>> the others only support complex, no Hermitian transpose.
>>   Barry
>> On Oct 22, 2008, at 2:40 AM, zhifeng sheng wrote:
>>> Hi,
>>> you mean the conjugate transpose for complex matrix is not
>>> supported?
>>> then how can you implement the iterative solvers for complex
>>> matrices? because, some iterative solvers need it.
>>> Thanks
>>> Best regards
>>> Hong Zhang wrote:
>>>> Zhifeng,
>>>> We do not have support for matrix operations on Hermitian matrix
>>>> yet.
>>>> Hong
>>>> On Mon, 20 Oct 2008, zhifeng sheng wrote:
>>>>> Dear all
>>>>> I am using this MatMatMultTranspose function for complex
>>>>> matrices, but it seems to be doing something weird.
>>>>> for instance, if I have complex matrix A, and I compute A^T*A
>>>>> with this function, it does not generate a Hermitian <http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatIsHermitian.html
>>>>> > matrix.
>>>>> I am thinking that maybe the function take the transpose of A
>>>>> instead of the conjugate transpose ....
>>>>> Do you know how I can get an A^H*A instead of A^T*A for complex
>>>>> matrices?
>>>>> Thanks a lot
>>>>> Best regards
>>>>> Zhifeng
