Problem with MatMatMultTranspose (con'd)
zhifeng sheng z.sheng at ewi.tudelft.nl
Thu Oct 23 09:36:58 CDT 2008
Hi
I have implemented the conjugate transpose, and it totally works for
complex matrices.
thanks for your help. but I think if you could just overload the
transpose function of complex matrices as conjugate transpose then
every solver should work on complex matrices automatically. Plus, I
don't think it is meaningful to compute the transpose of a complex matrix
thanks
Best regards
Zhifeng
Barry Smith wrote:
> On Oct 22, 2008, at 9:15 AM, zhifeng sheng wrote:
>> Dear all
>> suppose I have a complex matrix (Hermitian positive definite) to
>> solve, which KSP solver(s) can support solving it?
>> PS: for this moment, I don't need to take into account that the
>> matrix is hermitian.
> KSPCG and use KSPCGSetType(ksp,KSP_CG_HERMITIAN )
>> By the way, if I really need conjugate transpose function for complex
>> matrices, must I implement it myself?
> yes
>> (I mean, is there any function that I can make use of?)
>> Thanks
>> Best regards
>> Zhifeng
>> Barry Smith wrote:
>>>   There is only support for CG with Hermitian transpose, ksp_cg_type
>>> symmetric or hermitian, KSPCGSetType()
>>> the others only support complex, no Hermitian transpose.
>>>   Barry
>>> On Oct 22, 2008, at 2:40 AM, zhifeng sheng wrote:
>>>> Hi,
>>>> you mean the conjugate transpose for complex matrix is not supported?
>>>> then how can you implement the iterative solvers for complex
>>>> matrices? because, some iterative solvers need it.
>>>> Thanks
>>>> Best regards
>>>> Hong Zhang wrote:
>>>>> Zhifeng,
>>>>> We do not have support for matrix operations on Hermitian matrix yet.
>>>>> Hong
>>>>> On Mon, 20 Oct 2008, zhifeng sheng wrote:
>>>>>> Dear all
>>>>>> I am using this MatMatMultTranspose function for complex
>>>>>> matrices, but it seems to be doing something weird.
>>>>>> for instance, if I have complex matrix A, and I compute A^T*A
>>>>>> with this function, it does not generate a Hermitian
>>>>>> <http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatIsHermitian.html>
>>>>>> matrix.
>>>>>> I am thinking that maybe the function take the transpose of A
>>>>>> instead of the conjugate transpose ....
>>>>>> Do you know how I can get an A^H*A instead of A^T*A for complex
>>>>>> matrices?
>>>>>> Thanks a lot
>>>>>> Best regards
>>>>>> Zhifeng
