Problem with MatMatMultTranspose (con'd)
zhifeng sheng z.sheng at ewi.tudelft.nl
Wed Oct 22 09:15:25 CDT 2008
Dear all
suppose I have a complex matrix (Hermitian positive definite) to solve,
which KSP solver(s) can support solving it?
PS: for this moment, I don't need to take into account that the matrix
is hermitian.
By the way, if I really need conjugate transpose function for complex
matrices, must I implement it myself?
(I mean, is there any function that I can make use of?)
Thanks
Best regards
Zhifeng
Barry Smith wrote:
>    There is only support for CG with Hermitian transpose, ksp_cg_type
> symmetric or hermitian, KSPCGSetType()
> the others only support complex, no Hermitian transpose.
>    Barry
> On Oct 22, 2008, at 2:40 AM, zhifeng sheng wrote:
>> Hi,
>> you mean the conjugate transpose for complex matrix is not supported?
>> then how can you implement the iterative solvers for complex
>> matrices? because, some iterative solvers need it.
>> Thanks
>> Best regards
>> Hong Zhang wrote:
>>> Zhifeng,
>>> We do not have support for matrix operations on Hermitian matrix yet.
>>> Hong
>>> On Mon, 20 Oct 2008, zhifeng sheng wrote:
>>>> Dear all
>>>> I am using this MatMatMultTranspose function for complex matrices,
>>>> but it seems to be doing something weird.
>>>> for instance, if I have complex matrix A, and I compute A^T*A with
>>>> this function, it does not generate a Hermitian
>>>> <http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatIsHermitian.html>
>>>> matrix.
>>>> I am thinking that maybe the function take the transpose of A
>>>> instead of the conjugate transpose ....
>>>> Do you know how I can get an A^H*A instead of A^T*A for complex
>>>> matrices?
>>>> Thanks a lot
>>>> Best regards
>>>> Zhifeng
