Problem with MatMatMultTranspose
Wed Oct 22 07:23:23 CDT 2008
    There is only support for CG with Hermitian transpose, ksp_cg_type
symmetric or hermitian, KSPCGSetType()
the others only support complex, no Hermitian transpose.
    Barry
On Oct 22, 2008, at 2:40 AM, zhifeng sheng wrote:
> Hi,
> you mean the conjugate transpose for complex matrix is not supported?
> then how can you implement the iterative solvers for complex
> matrices? because, some iterative solvers need it.
> Thanks
> Best regards
> Hong Zhang wrote:
>> Zhifeng,
>> We do not have support for matrix operations on Hermitian matrix yet.
>> Hong
>> On Mon, 20 Oct 2008, zhifeng sheng wrote:
>>> Dear all
>>> I am using this MatMatMultTranspose function for complex matrices,
>>> but it seems to be doing something weird.
>>> for instance, if I have complex matrix A, and I compute A^T*A with
>>> this function, it does not generate a Hermitian <http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatIsHermitian.html
>>> > matrix.
>>> I am thinking that maybe the function take the transpose of A
>>> instead of the conjugate transpose ....
>>> Do you know how I can get an A^H*A instead of A^T*A for complex
>>> matrices?
>>> Thanks a lot
>>> Best regards
>>> Zhifeng
