cygwin/MPI-question
Thu Oct 16 06:04:46 CDT 2008
On Thu, Oct 16, 2008 at 5:42 AM, Franz Th. Langer <eplanung at t-online.de> wrote:
> Hi Satish,
> thanks very much for quick infos!
> I understand that I have to use  mpirun or mpiexec.
> (I still dont know how the system knows which procs can be used?)
> (in rexecshell one can fill in a list with the node-names)
> my questions arise out of the following situation:
> under cygwin:
> 1. I downloaded Petsc and made the necc. definitions
> 2. make all (everything ok!)
> 3. make test ( (everything ok!)
> under the tests there are also test for parallelizations!
> I still dont know how Petsc was doing this tests???
I assume you are using the latest release. In bmake/$PETSC_ARCH/petscconf
there is a definition of MPIRUN (or MPIEXEC) which is the location of that
program and it used to run the test by make.
  Matt
> I may have missed something , but I never found a call to mpirun or mpiexec?
> perhaps you can explain it?
> Best regards
> Franz
> Satish Balay wrote:
> On Thu, 16 Oct 2008, Franz Th. Langer wrote:
> Hi,
> System: Windows 2000, cygwin
> parallel computation with MPI
> (I am a newcomer to cygwin, I wrote a lot
> of par. progs for VC 6.0 +MPI.)
> compiling and linking of my par. petsc-program under cygwin is ok!
> I can run the program on 1 proc only!
> when I want to use more then 1 proc I am using Rexecshell!
> than the program querries about a wrong commandline?
> questions:
> -under cygwin: do I have to use  something else than Rexecshell?
> -what has than to be installed/initiated on the other procs?
> Cygwin is used only to build libraries. If you built PETSc with MPI -
> then you have to use the MPI startup mecanism [i.e mpiexec or mpirun]
> to start parallel MPI jobs.
> Satish
> Mit freundlichen Grüßen
> Dipl.-Ing. Franz Theodor Langer (Geschäftsführer)
> E_Planung GmbH
> Planung + Berechnung für Wissenschaft und Technik im Ingenieurbau
> Schlüsselbergstraße 30, 81673 München, Tel. 089/454933-0 Fax -14
> Geschäftsnummer: HRB 90116, Gerichtsstand: München
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
