cygwin/MPI-question
Franz Th. Langer eplanung at t-online.de
Thu Oct 16 05:42:43 CDT 2008
Hi Satish,
thanks very much for quick infos!
I understand that I have to use  mpirun or mpiexec.
(I still dont know how the system knows which procs can be used?)
(in rexecshell one can fill in a list with the node-names)
my questions arise out of the following situation:
under cygwin:
1. I downloaded Petsc and made the necc. definitions
2. make all (everything ok!)
3. make test ( (everything ok!)
under the tests there are also test for parallelizations!
I still dont know how Petsc was doing this tests???
I may have missed something , but I never found a call to mpirun or mpiexec?
perhaps you can explain it?
Best regards
Franz
Satish Balay wrote:
>On Thu, 16 Oct 2008, Franz Th. Langer wrote:
>>Hi,
>>System: Windows 2000, cygwin
>>parallel computation with MPI
>>(I am a newcomer to cygwin, I wrote a lot
>>of par. progs for VC 6.0 +MPI.)
>>compiling and linking of my par. petsc-program under cygwin is ok!
>>I can run the program on 1 proc only!
>>when I want to use more then 1 proc I am using Rexecshell!
>>than the program querries about a wrong commandline?
>>questions:
>>-under cygwin: do I have to use  something else than Rexecshell?
>>-what has than to be installed/initiated on the other procs?
>Cygwin is used only to build libraries. If you built PETSc with MPI -
>then you have to use the MPI startup mecanism [i.e mpiexec or mpirun]
>to start parallel MPI jobs.
>Satish
Mit freundlichen Grüßen
Dipl.-Ing. Franz Theodor Langer (Geschäftsführer)
E_Planung GmbH
Planung + Berechnung für Wissenschaft und Technik im Ingenieurbau
Schlüsselbergstraße 30, 81673 München, Tel. 089/454933-0 Fax -14
Geschäftsnummer: HRB 90116, Gerichtsstand: München
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081016/b451706b/attachment.htm>
