cygwin/MPI-question
Franz Th. Langer eplanung at t-online.de
Thu Oct 16 09:35:09 CDT 2008
Hi Matt,
thanks very much for help!
you are right I am using the latest version.
I found thedefinition of  MPIEXEC where mpiexec.exe is called.
when I want to run my program with more than
1 proc, where do I tell the systems which nodes I like to have?
is it enough  just to copy mpiexec.exe to the other nodes?
(I am new to cygwin!)
I was using rexecshell.exe all the time.
regards
Franz
Matthew Knepley wrote:
>On Thu, Oct 16, 2008 at 5:42 AM, Franz Th. Langer <eplanung at t-online.de> wrote:
>>Hi Satish,
>>thanks very much for quick infos!
>>I understand that I have to use  mpirun or mpiexec.
>>(I still dont know how the system knows which procs can be used?)
>>(in rexecshell one can fill in a list with the node-names)
>>my questions arise out of the following situation:
>>under cygwin:
>>1. I downloaded Petsc and made the necc. definitions
>>2. make all (everything ok!)
>>3. make test ( (everything ok!)
>>under the tests there are also test for parallelizations!
>>I still dont know how Petsc was doing this tests???
>I assume you are using the latest release. In bmake/$PETSC_ARCH/petscconf
>there is a definition of MPIRUN (or MPIEXEC) which is the location of that
>program and it used to run the test by make.
>  Matt
>>I may have missed something , but I never found a call to mpirun or mpiexec?
>>perhaps you can explain it?
>>Best regards
>>Franz
>>Satish Balay wrote:
>>On Thu, 16 Oct 2008, Franz Th. Langer wrote:
>>Hi,
>>System: Windows 2000, cygwin
>>parallel computation with MPI
>>(I am a newcomer to cygwin, I wrote a lot
>>of par. progs for VC 6.0 +MPI.)
>>compiling and linking of my par. petsc-program under cygwin is ok!
>>I can run the program on 1 proc only!
>>when I want to use more then 1 proc I am using Rexecshell!
>>than the program querries about a wrong commandline?
>>questions:
>>-under cygwin: do I have to use  something else than Rexecshell?
>>-what has than to be installed/initiated on the other procs?
>>Cygwin is used only to build libraries. If you built PETSc with MPI -
>>then you have to use the MPI startup mecanism [i.e mpiexec or mpirun]
>>to start parallel MPI jobs.
>>Satish
>>Mit freundlichen Grüßen
>>Dipl.-Ing. Franz Theodor Langer (Geschäftsführer)
>>E_Planung GmbH
>>Planung + Berechnung für Wissenschaft und Technik im Ingenieurbau
>>Schlüsselbergstraße 30, 81673 München, Tel. 089/454933-0 Fax -14
>>Geschäftsnummer: HRB 90116, Gerichtsstand: München
E_Planung GmbH
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20081016/c38b3a5d/attachment.htm>
