question
Nguyen, Hung V ERDC-ITL-MS Hung.V.Nguyen at usace.army.mil
Thu Oct 9 09:04:38 CDT 2008
All,
I am looking for an example code that read A (in csr format) and b. Then it
builds A and b petsc format and solves Ax = b.
I found an example below, but it seems that it doesn't work.
If you have similar like an example below or let me know where is a problem,
I would appreciate very much.
-Hung
        Purpose: Test a sparse matrix solver.
#include <stdio.h>
#include "petscksp.h"
int main(int argc,char **args)
        /* My sample sparse matrix A */
                 11.0   0    0  14.0  0
                 21.0  22.0  0  24.0  0
                 31.0   0   33. 34.0 35.0
                 0      0   43. 44.0  0
                 0      0    0   0   55.
        const int sizeMat=5;    // Matrix is 5 by 5.
        int i,j;
        int nonZero=12;
        double val[] ={11., 14.,21., 22., 24., 31., 33., 34., 35., 43., 44.,
55.};
        int col_ind[]={0, 3, 0, 1, 3, 0, 2, 3, 4, 2, 3, 4};
        int row_ptr[]={0, 2, 5, 9, 11, 12};
        double knB[]={2.0, 0.0, 1.0, 1.0, 2.0};
        double answer[]={-0.0348308, -0.152452, -0.150927, 0.170224,
0.0363636};
// calculate row_index, vector_index and number of nonzero per row:
        int nZperRow[]={3,4,2,1};
        int row_ind[]={0,0, 1,1,1, 2,2,2,2, 3,3, 4};
        int vec_ind[]={0,1,2,3,4};
        double initX[]={9.,9.,9.,9.,9.};
                PetSc codes start.
        printf("\n*** PetSC Testing phase. ***\n");
        /* Create variables of PetSc */
        Vec            x,b,u;  /* approx solution, RHS, exact solution
*/ /*a
linear system, Ax = b. */
        Mat            A;      /* linear system matrix */
        KSP            ksp;    /* linear solver context */
        PetscInt       Istart,Iend;     /* Index for local matrix of
each
processor */
        PetscInt       istart,iend;     /* Index for local vector of
each
processor */
        PetscViewer    viewer;
        PetscMPIInt    rank;
        PetscErrorCode ierr;
        PetscTruth     flg;
        static char help[] = "Parallel vector layout.\n\n";
        /* Initialization of PetSc */
        PetscInitialize(&argc,&args,(char*)0,help);
        MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
                Create parallel matrix, specifying only its global
dimensions. :
                When using MatCreate(), the matrix format can be specified at
                runtime. Also, the parallel partitioning of the matrix is
                determined by PETSc at runtime.
                Performance tuning note:  For problems of substantial size,
                preallocation of matrix memory is crucial for attaining good
                performance. See the matrix chapter of the users manual for
details.
                - Allocates memory for a sparse parallel matrix in AIJ format
                (the default parallel PETSc format: Compressed Sparse Row).
        ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
        ierr =
MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,sizeMat,sizeMat);CHKERRQ(ierr);
        ierr = MatSetType(A, MATAIJ);CHKERRQ(ierr);
        ierr = MatSetFromOptions(A);CHKERRQ(ierr);
                Currently, all PETSc parallel matrix formats are partitioned
by
                contiguous chunks of rows across the processors.
Determine
which
                rows of the matrix are locally owned.
        ierr = MatGetOwnershipRange(A,&Istart,&Iend);CHKERRQ(ierr);
        printf(" Rank= %d, Istart_row= %d, Iend_row+1 = %d \n", rank, Istart,
Iend);
                ierr =
MatMPIAIJSetPreallocationCSR(A,row_ptr,col_ind,PETSC_NULL);CHKERRQ(ierr)
// Standard format, CSR
                ierr =
MatSeqAIJSetPreallocation(A,0,nZperRow);CHKERRQ(ierr);
// Defining the number of nonzero for each row.
        ierr =
        ierr = MatSeqAIJSetPreallocation(A,0,nZperRow);CHKERRQ(ierr); //
                Set matrix elements in parallel.
                - Each processor needs to insert only elements that it owns
                        locally (but any non-local elements will be sent to
the
                        appropriate processor during matrix assembly).
                - Always specify global rows and columns of matrix entries.
        /* Method 1: Efficient method. */
        for (i=row_ptr[Istart]; i<row_ptr[Iend]; i++)
                //ierr =
MatSetValue(A,row_ind[i],col_ind[i],val[i],INSERT_VALUES);CHKERRQ(ierr);
                ierr =
MatSetValues(A,1,&(row_ind[i]),1,&(col_ind[i]),&(val[i]),INSERT_VALUES);
CHKER
RQ(ierr);
        ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
        ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
                Visaualize a matrix. Set a viewer's style.
                To see a dense matrix, use the following two lines:
                Line1: viewer = PETSC_VIEWER_STDOUT_(PETSC_COMM_WORLD);
                Line2: ierr =
PetscViewerSetFormat(viewer,PETSC_VIEWER_ASCII_DENSE);
        ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
                Create parallel vectors.
        ierr = VecCreate(PETSC_COMM_WORLD,&u);CHKERRQ(ierr);
        ierr = VecSetSizes(u,PETSC_DECIDE,sizeMat);CHKERRQ(ierr);
        ierr = VecSetFromOptions(u);CHKERRQ(ierr);
        ierr = VecDuplicate(u,&b);CHKERRQ(ierr);
        ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
                PETSc parallel vectors are partitioned by
Determine
                which vector are locally owned.
        VecGetOwnershipRange(b,&istart,&iend);
                Insert vector values
        VecSetValues(u,sizeMat,vec_ind,answer,INSERT_VALUES);
        VecSetValues(x,sizeMat,vec_ind,initX,INSERT_VALUES);
        VecSetValues(b,sizeMat,vec_ind,knB,INSERT_VALUES);
                Assemble vector, using the 2-step process:
                VecAssemblyBegin(), VecAssemblyEnd()
                Computations can be done while messages are in transition
                by placing code between these two statements.
        VecAssemblyBegin(u); VecAssemblyEnd(u);
        VecAssemblyBegin(x); VecAssemblyEnd(x);
        VecAssemblyBegin(b); VecAssemblyEnd(b);
                View the exact solution vector if desired
        if(rank==0) printf("Vector u: \n");
        flg = 1;
        if (flg) {ierr =
VecView(u,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);}
        if(rank==0) printf("Vector x: \n");
        if (flg) {ierr =
VecView(x,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);}
        if(rank==0) printf("Vector b: \n");
        if (flg) {ierr =
VecView(b,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);}
                Create the linear solver and set various options
        KSPCreate(PETSC_COMM_WORLD,&ksp);
        KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);
        KSPSetInitialGuessNonzero(ksp,PETSC_TRUE);
        KSPSetFromOptions(ksp);
                Solve the linear system
        KSPSolve(ksp,b,x);
        if(rank==0) printf("Solved Vector x: \n");
        if (flg) {ierr =
                Free work space.  All PETSc objects should be destroyed when
they are no longer needed.
        ierr = KSPDestroy(ksp);CHKERRQ(ierr);
        ierr = MatDestroy(A);CHKERRQ(ierr);
        ierr = VecDestroy(u);CHKERRQ(ierr);  ierr =
VecDestroy(x);CHKERRQ(ierr);
        ierr = VecDestroy(b);CHKERRQ(ierr);
        ierr = PetscFinalize();CHKERRQ(ierr);
        printf("\n");
        return 0;
