matrix inverse and multiplication
Sat Oct 4 18:11:16 CDT 2008
    In petsc-dev http://www-unix.mcs.anl.gov/petsc/petsc-as/developers/index.html
  use MatMatSolve() after
doing a MatLUFactorNumeric().
    C will always be dense, hence you input for B a SeqDense matrix,
not a sparse matrix. A can be sparse.
    Barry
On Oct 4, 2008, at 5:58 PM, Manav Bhatia wrote:
> Hi
>   I have a problem with two sparse matrices: A and B where I need to
> calculate the following:
> C = A^{-1} B
>   What is the best way to do this? Is there a better way to do it
> than to calculate the columns of C by a linear solution with
> individual columns of B as rhs vectors?
>   Also, is it possible to have a-priori knowledge of sparsity
> pattern of C for two sparse matrices A and B?
> Regards,
> Manav
