question
Thu Oct 9 09:24:03 CDT 2008
   You can use the utilities: MatCreateSeqAIJWithArrays() or
MatCreateMPIAIWithArrays() they
handle all the details for you.
    Barry
On Oct 9, 2008, at 9:04 AM, Nguyen, Hung V ERDC-ITL-MS wrote:
> All,
> I am looking for an example code that read A (in csr format) and b.
> Then it
> builds A and b petsc format and solves Ax = b.
> I found an example below, but it seems that it doesn't work.
> If you have similar like an example below or let me know where is a
> problem,
> I would appreciate very much.
> Thanks,
> -Hung
>        Purpose: Test a sparse matrix solver.
> #include <stdio.h>
> #include "petscksp.h"
> int main(int argc,char **args)
>        /* My sample sparse matrix A */
>                 11.0   0    0  14.0  0
>                 21.0  22.0  0  24.0  0
>                 31.0   0   33. 34.0 35.0
>                 0      0   43. 44.0  0
>                 0      0    0   0   55.
>        const int sizeMat=5;    // Matrix is 5 by 5.
>        int i,j;
>        int nonZero=12;
>        double val[] ={11., 14.,21., 22., 24., 31., 33., 34., 35.,
> 43., 44.,
> 55.};
>        int col_ind[]={0, 3, 0, 1, 3, 0, 2, 3, 4, 2, 3, 4};
>        int row_ptr[]={0, 2, 5, 9, 11, 12};
>        double knB[]={2.0, 0.0, 1.0, 1.0, 2.0};
>        double answer[]={-0.0348308, -0.152452, -0.150927, 0.170224,
> 0.0363636};
> // calculate row_index, vector_index and number of nonzero per row:
>        int nZperRow[]={3,4,2,1};
>        int row_ind[]={0,0, 1,1,1, 2,2,2,2, 3,3, 4};
>        int vec_ind[]={0,1,2,3,4};
>        double initX[]={9.,9.,9.,9.,9.};
>                PetSc codes start.
>        printf("\n*** PetSC Testing phase. ***\n");
>        /* Create variables of PetSc */
>        Vec            x,b,u;  /* approx solution, RHS, exact solution
> */ /*a
> linear system, Ax = b. */
>        Mat            A;      /* linear system matrix */
>        KSP            ksp;    /* linear solver context */
>        PetscInt       Istart,Iend;     /* Index for local matrix of
> each
> processor */
>        PetscInt       istart,iend;     /* Index for local vector of
> each
> processor */
>        PetscViewer    viewer;
>        PetscMPIInt    rank;
>        PetscErrorCode ierr;
>        PetscTruth     flg;
>        static char help[] = "Parallel vector layout.\n\n";
>        /* Initialization of PetSc */
>        PetscInitialize(&argc,&args,(char*)0,help);
>        MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>                Create parallel matrix, specifying only its global
> dimensions. :
>                When using MatCreate(), the matrix format can be
> specified at
>                runtime. Also, the parallel partitioning of the
> matrix is
>                determined by PETSc at runtime.
>                Performance tuning note:  For problems of substantial
> size,
>                preallocation of matrix memory is crucial for
> attaining good
>                performance. See the matrix chapter of the users
> manual for
> details.
>                - Allocates memory for a sparse parallel matrix in
> AIJ format
>                (the default parallel PETSc format: Compressed Sparse
> Row).
>        ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>        ierr =
> MatSetSizes
> (A,PETSC_DECIDE,PETSC_DECIDE,sizeMat,sizeMat);CHKERRQ(ierr);
>        ierr = MatSetType(A, MATAIJ);CHKERRQ(ierr);
>        ierr = MatSetFromOptions(A);CHKERRQ(ierr);
>                Currently, all PETSc parallel matrix formats are
> partitioned
> by
>                contiguous chunks of rows across the processors.
> Determine
> which
>                rows of the matrix are locally owned.
>        ierr = MatGetOwnershipRange(A,&Istart,&Iend);CHKERRQ(ierr);
>        printf(" Rank= %d, Istart_row= %d, Iend_row+1 = %d \n", rank,
> Istart,
> Iend);
>                ierr =
> MatMPIAIJSetPreallocationCSR
> (A,row_ptr,col_ind,PETSC_NULL);CHKERRQ(ierr)
> // Standard format, CSR
>                ierr =
> MatSeqAIJSetPreallocation(A,0,nZperRow);CHKERRQ(ierr);
> // Defining the number of nonzero for each row.
>        ierr =
>        ierr = MatSeqAIJSetPreallocation(A,
> 0,nZperRow);CHKERRQ(ierr); //
>                Set matrix elements in parallel.
>                - Each processor needs to insert only elements that
> it owns
>                        locally (but any non-local elements will be
> sent to
> the
>                        appropriate processor during matrix assembly).
>                - Always specify global rows and columns of matrix
> entries.
>        /* Method 1: Efficient method. */
>        for (i=row_ptr[Istart]; i<row_ptr[Iend]; i++)
>                //ierr =
> MatSetValue
> (A,row_ind[i],col_ind[i],val[i],INSERT_VALUES);CHKERRQ(ierr);
>                ierr =
> MatSetValues(A,1,&(row_ind[i]),
> 1,&(col_ind[i]),&(val[i]),INSERT_VALUES);
> CHKER
> RQ(ierr);
>        ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>        ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>                Visaualize a matrix. Set a viewer's style.
>                To see a dense matrix, use the following two lines:
>                Line1: viewer = PETSC_VIEWER_STDOUT_(PETSC_COMM_WORLD);
>                Line2: ierr =
> PetscViewerSetFormat(viewer,PETSC_VIEWER_ASCII_DENSE);
>        ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>                Create parallel vectors.
>        ierr = VecCreate(PETSC_COMM_WORLD,&u);CHKERRQ(ierr);
>        ierr = VecSetSizes(u,PETSC_DECIDE,sizeMat);CHKERRQ(ierr);
>        ierr = VecSetFromOptions(u);CHKERRQ(ierr);
>        ierr = VecDuplicate(u,&b);CHKERRQ(ierr);
>        ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
>                PETSc parallel vectors are partitioned by
> Determine
>                which vector are locally owned.
>        VecGetOwnershipRange(b,&istart,&iend);
>                Insert vector values
>        VecSetValues(u,sizeMat,vec_ind,answer,INSERT_VALUES);
>        VecSetValues(x,sizeMat,vec_ind,initX,INSERT_VALUES);
>        VecSetValues(b,sizeMat,vec_ind,knB,INSERT_VALUES);
>                Assemble vector, using the 2-step process:
>                VecAssemblyBegin(), VecAssemblyEnd()
>                Computations can be done while messages are in
> transition
>                by placing code between these two statements.
>        VecAssemblyBegin(u); VecAssemblyEnd(u);
>        VecAssemblyBegin(x); VecAssemblyEnd(x);
>        VecAssemblyBegin(b); VecAssemblyEnd(b);
>                View the exact solution vector if desired
>        if(rank==0) printf("Vector u: \n");
>        flg = 1;
>        if (flg) {ierr =
> VecView(u,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);}
>        if(rank==0) printf("Vector x: \n");
>        if (flg) {ierr =
> VecView(x,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);}
>        if(rank==0) printf("Vector b: \n");
>        if (flg) {ierr =
> VecView(b,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);}
>                Create the linear solver and set various options
>        KSPCreate(PETSC_COMM_WORLD,&ksp);
>        KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);
>        KSPSetInitialGuessNonzero(ksp,PETSC_TRUE);
>        KSPSetFromOptions(ksp);
>                Solve the linear system
>        KSPSolve(ksp,b,x);
>        if(rank==0) printf("Solved Vector x: \n");
>        if (flg) {ierr =
>                Free work space.  All PETSc objects should be
> destroyed when
> they are no longer needed.
>        ierr = KSPDestroy(ksp);CHKERRQ(ierr);
>        ierr = MatDestroy(A);CHKERRQ(ierr);
>        ierr = VecDestroy(u);CHKERRQ(ierr);  ierr =
> VecDestroy(x);CHKERRQ(ierr);
>        ierr = VecDestroy(b);CHKERRQ(ierr);
>        ierr = PetscFinalize();CHKERRQ(ierr);
>        printf("\n");
>        return 0;
