Can't run ./configure at installation
Wed Mar 26 08:01:54 CDT 2008
what do you have for:
which make
which diff
Satish
On Wed, 26 Mar 2008, Ben Tay wrote:
> Hi,
> I guess it's because I've another copy of Python for windows installed by
> Tecplot. Uninstalled it and reinstall my cygwin. However I got this msg:
>             Configuring PETSc to compile on your system
> *** Incomplete cygwin install detected
> *** Please rerun cygwin-setup and install module make [and its
> dependencies]***
> I run "make" and it seems to be. What do you mean by dependencies? I just
> select "gnu make" in the developer's installation of cygwin (and python
> 8000+k). That's what I've been using and it worked last time. I wonder what
> other additions must I install?
> Thank you.
> Matthew Knepley wrote:
> > On Mon, Mar 24, 2008 at 8:57 PM, Ben Tay <zonexo at gmail.com> wrote:
> > > Hmm,
> > >  Tried to reinstall Python but it still can't work. Any other idea?
> > In order to install you must get a working copy of Python. I suspect you
> > have
> > not fully uninstalled that copy. I would reinstall cygwin completely, since
> > it
> > appears that you have a corrupt copy.
> >   Matt
> > >  Thanks again!
> > >  > Python is fundamentally broken. I recommend a reinstall. That
> > >  > 'import site' error indicates that Python cannot load its builtin
> > > library.
> > >  >    Matt
> > >  > On Mon, Mar 24, 2008 at 8:22 PM, Ben Tay <zonexo at gmail.com> wrote:
> > >  >> Hi,
> > >  >>  I'm trying to install a new version of PETSc into windows using
> > > cygwin.
> > >  >>  I met with the following error at installation:
> > >  >>  $ ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe
> > > f90'
> > >  >>  --download-f-blas-lapack=1 LIBS="-L'/cygdrive/c/Program
> > > Files/Microsoft
> > >  >>  Visual Studio/DF98/LIB'"
> > >  >>  'import site' failed; use -v for traceback
> > >  >>  Traceback (most recent call last):
> > >  >>   File "./config/configure.py", line 2, in <module>
> > >  >>     import os
> > >  >>  ImportError: No module named os
> > >  >>  May I know why is this happening?
> > >  >>  Thank you very much.
> > >  >>  Regards.
