snes querie
Dave Lee dave at vpac.org
Tue Mar 25 21:39:30 CDT 2008
Hello PETSc,
I'm trying to solve a non-linear problem using the SNES routines, and i've been
finding that for every even time step the solution converges as I'd expect, however
for every odd time step, the solution diverges. I've run an additional test problem
for which the solution diverges on the second time step only (ie: converges for every
successive time step), so I'm pretty sure its not a odd/even logic problem in my
code. The output (for the initial guess and first two time steps) when I run with
the flags -info -snes_monitor is as follows:
[0] KSPDefaultConverged(): Linear solver has converged. Residual norm 9.34921e-14 is less than relative tolerance 1e-05 times initial right hand side norm 48.7135 at iteration 1
[0] SNESSolve_LS(): iter=0, linear solve iterations=1
[0] SNESLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 112.285 near zero implies inconsistent rhs
[0] SNESLineSearchCubic(): Using full step
[0] SNESSolve_LS(): fnorm=3.0170114380870206e+01, gnorm=1.0142108262591121e-12, ynorm=4.8713530783010192e+01, lssucceed=1
  1 SNES Function norm 1.014210826259e-12
[0] SNESDefaultConverged(): Converged due to function norm 1.01421e-12 < 3.01701e-07 (relative tolerance)
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE
[0] SNESSolve_LS(): iter=0, linear solve iterations=8
[0] SNESLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 0.925505 near zero implies inconsistent rhs
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430941e-02
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430942e-03
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430942e-04
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430944e-05
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430946e-06
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430949e-07
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430952e-08
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430954e-09
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430954e-10
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430954e-11
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430954e-12
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430954e-13
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430956e-14
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430958e-15
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430960e-16
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430961e-17
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430961e-18
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430962e-19
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430962e-20
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430964e-21
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430967e-22
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430969e-23
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430971e-24
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430971e-25
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430974e-26
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430976e-27
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430979e-28
[0] SNESLineSearchCubic(): Cubic step no good, shrinking lambda,  lambda=2.6904093002430979e-29
[0] SNESLineSearchCubic(): Unable to find good step length! 29
[0] SNESLineSearchCubic(): fnorm=9.6575221913187848e-01, gnorm=2.0934668664952425e+00, ynorm=5.1772194669712386e+00, lambda=2.6904093002430979e-29, initial slope=-9.3267734652255951e-01
[0] SNESSolve_LS(): fnorm=9.6575221913187848e-01, gnorm=2.0934668664952425e+00, ynorm=5.1772194669712386e+00, lssucceed=0
  1 SNES Function norm 2.093466866495e+00
[0] SNESLSCheckLocalMin_Private(): || J^T F|| 107.04 near zero implies found a local minimum
Nonlinear solve did not converge due to DIVERGED_LS_FAILURE
  0 SNES Function norm 2.185496756061e+00
[0] KSPDefaultConverged(): Linear solver has converged. Residual norm 2.29435e-06 is less than relative tolerance 1e-05 times initial right hand side norm 3.74384 at iteration 8
[0] SNESLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 119.216 near zero implies inconsistent rhs
[0] SNESSolve_LS(): fnorm=2.1854967560609060e+00, gnorm=1.1219829200815006e+00, ynorm=6.0664603876861261e+00, lssucceed=1
  1 SNES Function norm 1.121982920082e+00
[0] KSPDefaultConverged(): Linear solver has converged. Residual norm 1.49325e-06 is less than relative tolerance 1e-05 times initial right hand side norm 1.54195 at iteration 7
[0] SNESSolve_LS(): iter=1, linear solve iterations=7
[0] SNESLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 1.58793 near zero implies inconsistent rhs
[0] SNESSolve_LS(): fnorm=1.1219829200815006e+00, gnorm=2.6934556136855723e-02, ynorm=1.5405251272601992e+00, lssucceed=1
  2 SNES Function norm 2.693455613686e-02
[0] KSPDefaultConverged(): Linear solver has converged. Residual norm 3.31729e-08 is less than relative tolerance 1e-05 times initial right hand side norm 0.0334934 at iteration 7
[0] SNESSolve_LS(): iter=2, linear solve iterations=7
[0] SNESLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 1.36601 near zero implies inconsistent rhs
[0] SNESSolve_LS(): fnorm=2.6934556136855723e-02, gnorm=6.6982884106362914e-04, ynorm=3.3460040092452174e-02, lssucceed=1
  3 SNES Function norm 6.698288410636e-04
[0] KSPDefaultConverged(): Linear solver has converged. Residual norm 7.22802e-10 is less than relative tolerance 1e-05 times initial right hand side norm 0.000832349 at iteration 7
[0] SNESSolve_LS(): iter=3, linear solve iterations=7
[0] SNESLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 1.30347 near zero implies inconsistent rhs
[0] SNESSolve_LS(): fnorm=6.6982884106362914e-04, gnorm=1.7317637296224453e-05, ynorm=8.3135074665742882e-04, lssucceed=1
  4 SNES Function norm 1.731763729622e-05
[0] KSPDefaultConverged(): Linear solver has converged. Residual norm 1.77439e-11 is less than relative tolerance 1e-05 times initial right hand side norm 2.04787e-05 at iteration 7
[0] SNESSolve_LS(): iter=4, linear solve iterations=7
[0] SNESLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 1.14134 near zero implies inconsistent rhs
[0] SNESSolve_LS(): fnorm=1.7317637296224453e-05, gnorm=4.5421644145512881e-07, ynorm=2.0457661052256775e-05, lssucceed=1
  5 SNES Function norm 4.542164414551e-07
[0] KSPDefaultConverged(): Linear solver has converged. Residual norm 4.11491e-13 is less than relative tolerance 1e-05 times initial right hand side norm 5.14482e-07 at iteration 7
[0] SNESSolve_LS(): iter=5, linear solve iterations=7
[0] SNESLSCheckResidual_Private(): ||J^T(F-Ax)||/||F-AX|| 1.24632 near zero implies inconsistent rhs
[0] SNESSolve_LS(): fnorm=4.5421644145512881e-07, gnorm=1.1954313416752086e-08, ynorm=5.1403324849206651e-07, lssucceed=1
  6 SNES Function norm 1.195431341675e-08
[0] SNESDefaultConverged(): Converged due to function norm 1.19543e-08 < 2.1855e-08 (relative tolerance)
I'm not sure what to make of the statement:
which arises for both the converged time steps and the unresolved time steps - should I be concerned
about this?
Also at the point where the SNESComputeFunction call is repeatedly made (ls.c:645) during the unresolved
time steps, the system is not actually being solved, as the condition on lambda is not being met, so
the SNESLineSearchCubic function just keeps calling the residual assembly function.
Any ideas what all of this means?
cheers, dave.
