Can't run ./configure at installation
Ben Tay zonexo at gmail.com
Wed Mar 26 01:35:48 CDT 2008
I guess it's because I've another copy of Python for windows installed
by Tecplot. Uninstalled it and reinstall my cygwin. However I got this msg:
             Configuring PETSc to compile on your system
 *** Incomplete cygwin install detected
 *** Please rerun cygwin-setup and install module make [and its
dependencies]***
I run "make" and it seems to be. What do you mean by dependencies? I
just select "gnu make" in the developer's installation of cygwin (and
python 8000+k). That's what I've been using and it worked last time. I
wonder what other additions must I install?
Thank you.
Matthew Knepley wrote:
> On Mon, Mar 24, 2008 at 8:57 PM, Ben Tay <zonexo at gmail.com> wrote:
>> Hmm,
>>  Tried to reinstall Python but it still can't work. Any other idea?
> In order to install you must get a working copy of Python. I suspect you have
> not fully uninstalled that copy. I would reinstall cygwin completely, since it
> appears that you have a corrupt copy.
>   Matt
>>  Thanks again!
>>  > Python is fundamentally broken. I recommend a reinstall. That
>>  > 'import site' error indicates that Python cannot load its builtin library.
>>  >    Matt
>>  > On Mon, Mar 24, 2008 at 8:22 PM, Ben Tay <zonexo at gmail.com> wrote:
>>  >> Hi,
>>  >>  I'm trying to install a new version of PETSc into windows using cygwin.
>>  >>  I met with the following error at installation:
>>  >>  $ ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe f90'
>>  >>  --download-f-blas-lapack=1 LIBS="-L'/cygdrive/c/Program Files/Microsoft
>>  >>  Visual Studio/DF98/LIB'"
>>  >>  'import site' failed; use -v for traceback
>>  >>  Traceback (most recent call last):
>>  >>   File "./config/configure.py", line 2, in <module>
>>  >>     import os
>>  >>  ImportError: No module named os
>>  >>  May I know why is this happening?
>>  >>  Thank you very much.
>>  >>  Regards.
