Using PETSc libraries with MS Compute cluster and MS MPI
Thu Apr 24 12:19:58 CDT 2008
    Ben,
      This is an error in our config/configure.py model (and
autoconf's as well) that does not properly
do the library checks under certain uncommon circumstances, it is not
so easy for us to fix since we
do not have access to the Microsoft cluster environment.
    Barry
On Apr 24, 2008, at 4:11 AM, Ben Tay wrote:
> Hi,
> I'm trying to run my mpi code on the MS Compute cluster which my
> school just installed. Unfortunately, it failed without giving any
> error msg. I am using just a test example ex2f.
> I read in the MS website that there is no need to use MS MPI to
> compile the code or library.
> Anyway, I also tried to compile PETSc with MS MPI but I'm not able
> to get pass ./configure. It always complains that there is something
> wrong with the MS MPI.
> Is there anyone who has experience in these?
> Thank you very much.
> Regards.
