Using PETSc libraries with MS Compute cluster and MS MPI
Farshid Mossaiby mossaiby at yahoo.com
Thu Apr 24 16:29:01 CDT 2008
Ben,
Have you used headers and libraries from Compute
Cluster SDK for your configure? I doubt you can run
programs compiled with MPICH, for example, on WCCS.
I am going to try this in the next step of my work, so
please share your findings.
Farshid Mossaiby
--- Barry Smith <bsmith at mcs.anl.gov> wrote:
>     Ben,
>       This is an error in our config/configure.py
> model (and
> autoconf's as well) that does not properly
> do the library checks under certain uncommon
> circumstances, it is not
> so easy for us to fix since we
> do not have access to the Microsoft cluster
> environment.
>     Barry
> On Apr 24, 2008, at 4:11 AM, Ben Tay wrote:
> > Hi,
> > I'm trying to run my mpi code on the MS Compute
> cluster which my
> > school just installed. Unfortunately, it failed
> without giving any
> > error msg. I am using just a test example ex2f.
> > I read in the MS website that there is no need to
> use MS MPI to
> > compile the code or library.
> > Anyway, I also tried to compile PETSc with MS MPI
> but I'm not able
> > to get pass ./configure. It always complains that
> there is something
> > wrong with the MS MPI.
> > Is there anyone who has experience in these?
> > Thank you very much.
> > Regards.
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
