DA question
Randall Mackie rlmackie862 at gmail.com
Wed Apr 9 15:09:59 CDT 2008
Hi Amit,
Why do you need two staggered grids? I do EM finite difference frequency
domain modeling on a staggered grid using just one DA. Works perfectly fine.
There are some grid points that are not used, but you just set them to zero
and put a 1 on the diagonal of the coefficient matrix.
Randy
Amit.Itagi at seagate.com wrote:
> Hi Berend,
> A detailed explanation of the finite difference scheme is given here :
> http://en.wikipedia.org/wiki/Finite-difference_time-domain_method
> Thanks
> Rgds,
> Amit
>              Berend van Wachem
>              <berend at chalmers.
>              se>                                                        To
>              Sent by:                  petsc-users at mcs.anl.gov
>              owner-petsc-users                                          cc
>              @mcs.anl.gov
>              No Phone Info                                         Subject
>              Available                 Re: DA question
>              04/09/2008 02:59
>              PM
>              Please respond to
>                   nl.gov
> Dear Amit,
> Could you explain how the two grids are attached?
> I am using multiple DA's for multiple structured grids glued together.
> I've done the gluing with setting up various IS objects. From the
> multiple DA's, one global variable vector is formed. Is that what you
> are looking for?
> Best regards,
> Berend.
>> Hi,
>> Is it possible to use DA to perform finite differences on two staggered
>> regular grids (as in the electromagnetic finite difference time domain
>> method) ? Surrounding nodes from one grid are used to update the value in
>> the dual grid. In addition, local manipulations need to be done on the
>> nodal values.
>> Thanks
>> Rgds,
>> Amit
