Version of Mpi and fblaslapack
Thu Oct 11 22:44:00 CDT 2007
For clarification - blas/lapack & MPI have standard interfaces - so
any version of these packages should work fine with all versions of
PETSc.
Satish
On Thu, 11 Oct 2007, Lisandro Dalcin wrote:
> I would suggest you to manually install MPI (MPICH2 perhpas works, if
> not, use MPICH1), and install blas and lapack (if you are on linux,
> it's far easier to look for those packages on your distro repo).
> But perhaps the best thing is to figure out the crash... Can you send
> de ouput of the crash, and perhaps run your application using
> valgrind?
> On 10/11/07, Trivedi, Jagruti CIV 470000D, 474300D
> <jagruti.trivedi at navy.mil> wrote:
> > Hi there,
> > How do you find out which version of mpi and fblaslapack you need with which
> > version of PetSc?
> > I am interested in PetSc 2.2.1. I need to install PetSc 2.2.1 to recreate
> > the working scenerio for my
> > Application.
> > My application compiled and linked ok with PetSc 2.3.3 but it crashes so I
> > need to duplicate my
> > Application working on PetSc 2.2.1.
> > If I run config/configure.py with download option, it downloads the latest
> > version of mpi and fblaslapak.
> > B/R,
> > ?Jagruti
