Can't read MPIRUN_HOST
Ben Tay zonexo at gmail.com
Mon May 21 23:34:41 CDT 2007
ok. I sorted out that problem. Now I got this error:
*** glibc detected *** double free or corruption (!prev): 0x0000000000509660
/usr/lsf62/bin/mvapich_wrapper: line 388: 28571 Aborted
(core dumped) $PJL $PJL_OPTS $REMOTE_ENV_VAR $JOB_CMD
Job  /usr/lsf62/bin/mvapich_wrapper ./ex1f
TID   HOST_NAME   COMMAND_LINE            STATUS            TERMINATION_TIME
00001 atlas3-c63                   Undefined
00002 atlas3-c63                   Undefined
00002 atlas3-c61 ./ex1f            Signaled (SIGKILL)       05/22/2007
12:23:58
00003 atlas3-c61                   Undefined
Thanks
On 5/22/07, Satish Balay <balay at mcs.anl.gov> wrote:
> I don't think this has anything to do with PETSc. You might want to
> check the docs of MPI library or the batch system you are using.
> Satish
> On Tue, 22 May 2007, Ben Tay wrote:
> > Hi,
> > I tried to compile PETSc and there's no problem. I also used the
> > *--with-batch=1
> > *option since my server is using a job scheduler. There's no shared
> library
> > and I'm installing hypre too.
> > However, when after sending the job for ex1f, I got the error msg:
> > Can't read MPIRUN_HOST.
> > So what's the problem?
> > thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070522/da904f4c/attachment.htm>
