Can't read MPIRUN_HOST
Mon May 21 23:09:32 CDT 2007
I don't think this has anything to do with PETSc. You might want to
check the docs of MPI library or the batch system you are using.
Satish
On Tue, 22 May 2007, Ben Tay wrote:
> Hi,
> I tried to compile PETSc and there's no problem. I also used the
> *--with-batch=1
> *option since my server is using a job scheduler. There's no shared library
> and I'm installing hypre too.
> However, when after sending the job for ex1f, I got the error msg:
> Can't read MPIRUN_HOST.
> So what's the problem?
> thanks
