Can't read MPIRUN_HOST
Tue May 22 00:04:48 CDT 2007
Is this a PETSc example? Which one is it?
Satish
On Tue, 22 May 2007, Ben Tay wrote:
> ok. I sorted out that problem. Now I got this error:
> *** glibc detected *** double free or corruption (!prev): 0x0000000000509660
> /usr/lsf62/bin/mvapich_wrapper: line 388: 28571 Aborted
> (core dumped) $PJL $PJL_OPTS $REMOTE_ENV_VAR $JOB_CMD
> Job  /usr/lsf62/bin/mvapich_wrapper ./ex1f
> TID   HOST_NAME   COMMAND_LINE            STATUS            TERMINATION_TIME
> 00001 atlas3-c63                   Undefined
> 00002 atlas3-c63                   Undefined
> 00002 atlas3-c61 ./ex1f            Signaled (SIGKILL)       05/22/2007
> 12:23:58
> 00003 atlas3-c61                   Undefined
> Thanks
> On 5/22/07, Satish Balay <balay at mcs.anl.gov> wrote:
> > I don't think this has anything to do with PETSc. You might want to
> > check the docs of MPI library or the batch system you are using.
> > Satish
> > > Hi,
> > > I tried to compile PETSc and there's no problem. I also used the
> > > *--with-batch=1
> > > *option since my server is using a job scheduler. There's no shared
> > library
> > > and I'm installing hypre too.
> > > However, when after sending the job for ex1f, I got the error msg:
> > > Can't read MPIRUN_HOST.
> > > So what's the problem?
> > > thanks
