problems with ACML and single precision
Thu Jun 28 13:50:12 CDT 2007
Yes, you need to let us compile for single precision. Use the option in the
error message.
    Matt
On 6/28/07, Roberto Gori <r.gori at cineca.it> wrote:
> Hi,
> i'm trying to install PETSc 2.3.3-p3 on a Linux amd64 cluster.
> There's no problems wìth double precison but when I add the single precision
> option to my configure command I get the following error:
>              Configuring PETSc to compile on your system
> TESTING: checkMissing from
> config.packages.BlasLapack(python/BuildSystem/config/packages/BlasLapack.py:446)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Need to use --download-c-blas-lapack when using
> --with-precision=longdouble/single
> This is my configure:
> config/configure.py --with-mpirun=mpirun.lsf --with-shared=0
> --with-blas-lib=/cineca/prod/acml/3.6.0/ifort64/lib/libacml.a
> --with-lapack-lib=/cineca/prod/acml/3.6.0/ifort64/lib/libacml.a
> --with-precision=single
> Maybe ACML is not supported for single precision?
> Thanks
>     Roberto
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
