problems with ACML and single precision
Roberto Gori r.gori at cineca.it
Fri Jun 29 04:06:18 CDT 2007
Thank you Matthew,
I tried,
now my configure looks like this:
>config/configure.py --with-mpirun=mpirun.lsf --with-shared=0  --with-precision=single --download-c-blas-lapack=yes
and I get the following error:
             Configuring PETSc to compile on your system
TESTING: configureLibrary from config.packages.BlasLapack(python/BuildSystem/config/packages/BlasLapack.py:384)        *********************************************************************************
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Should request f-blas-lapack, not --download-c-blas-lapack=yes since you have a fortran compiler?
so i changed my configure:
>config/configure.py --with-mpirun=mpirun.lsf --with-shared=0  --with-precision=single --download-f-blas-lapack=yes
Compiling FBLASLAPACK; this may take several minutes        =================================================================================
TESTING: checkMissing from config.packages.BlasLapack(python/BuildSystem/config/packages/BlasLapack.py:446)        *********************************************************************************
Need to use --download-c-blas-lapack when using --with-precision=longdouble/single
I'm in loop.
Moreover to achieve better performance i would prefer to use acml instead of the BlasLapack sources.
Everything works when i build petsc 2.3.1 with the Intel's compiler. I'm not able to do that with petsc 2.3.2.
    Roberto
  ----- Original Message -----
  To: petsc-users at mcs.anl.gov
  Sent: Thursday, June 28, 2007 8:50 PM
  Subject: Re: problems with ACML and single precision
  Yes, you need to let us compile for single precision. Use the option in the
  error message.
      Matt
  On 6/28/07, Roberto Gori <r.gori at cineca.it> wrote:
  > Hi,
  > i'm trying to install PETSc 2.3.3-p3 on a Linux amd64 cluster.
  > There's no problems wìth double precison but when I add the single precision
  > option to my configure command I get the following error:
  > details):
  > This is my configure:
  > --with-blas-lib=/cineca/prod/acml/3.6.0/ifort64/lib/libacml.a
  > --with-lapack-lib=/cineca/prod/acml/3.6.0/ifort64/lib/libacml.a
  > Maybe ACML is not supported for single precision?
  > Thanks
  >     Roberto
  experiments is infinitely more interesting than any results to which
  their experiments lead.
  -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070629/dc246292/attachment.htm>
