problems with ACML and single precision
Roberto Gori r.gori at cineca.it
Thu Jun 28 12:09:55 CDT 2007
i'm trying to install PETSc 2.3.3-p3 on a Linux amd64 cluster.
There's no problems wìth double precison but when I add the single precision option to my configure command I get the following error:
             Configuring PETSc to compile on your system
TESTING: checkMissing from config.packages.BlasLapack(python/BuildSystem/config/packages/BlasLapack.py:446)        *********************************************************************************
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Need to use --download-c-blas-lapack when using --with-precision=longdouble/single
This is my configure:
config/configure.py --with-mpirun=mpirun.lsf --with-shared=0 --with-blas-lib=/cineca/prod/acml/3.6.0/ifort64/lib/libacml.a --with-lapack-lib=/cineca/prod/acml/3.6.0/ifort64/lib/libacml.a --with-precision=single
Maybe ACML is not supported for single precision?
Thanks
    Roberto
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070628/0e199087/attachment.htm>
