A 3D example of KSPSolve?
Fri Feb 9 21:06:43 CST 2007
You really have to give us the log summary output. None of the relevant
numbers are in your summary.
   Matt
On 2/9/07, Shi Jin <jinzishuai at yahoo.com> wrote:
> Dear Barry,
> Thank you.
> I actually have done the staging already.
> I summarized the timing of the runs in google online
> spreadsheets. I have two runs.
> 1. with 400,000 finite elements:
> http://spreadsheets.google.com/pub?key=pZHoqlL60quZeDZlucTjEIA
> 2. with 1,600,000 finite elements:
> http://spreadsheets.google.com/pub?key=pZHoqlL60quZcCVLAqmzqQQ
> If you can take a look at them and give me some
> advice, I will be deeply grateful.
> Shi
> --- Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   NO, NO, don't spend time stripping your code!
> > Unproductive
> >   See the manul pages for PetscLogStageRegister(),
> > PetscLogStagePush() and
> > PetscLogStagePop(). All you need to do is maintain a
> > seperate stage for each
> > of your KSPSolves; in your case you'll create 3
> > stages.
> >    Barry
> > On Fri, 9 Feb 2007, Shi Jin wrote:
> > > Thank you.
> > > But my code has 10 calls to KSPSolve of three
> > > different linear systems at each time update.
> > Should I
> > > strip it down to a single KSPSolve so that it is
> > > easier to analysis? I might have the code dump the
> > > Matrix and vector and write another code to read
> > them
> > > into and call KSPSolve. I don't know whether this
> > is
> > > worth doing  or should I just send in the messy
> > log
> > > file of the whole run.
> > > Thanks for any advice.
> > > Shi
> > > >   Shi,
> > > >    There is never a better test problem then
> > your
> > > > actual problem.
> > > > Send the results from running on 1, 4, and 8
> > > > processes with the options
> > > > -log_summary -ksp_view (use the optimized
> > version of
> > > > PETSc (running
> > > > config/configure.py --with-debugging=0))
> > > >   Barry
> > > > > Hi there,
> > > > > I am tuning our 3D FEM CFD code written with
> > > > PETSc.
> > > > > The code doesn't scale very well. For example,
> > > > with 8
> > > > > processes on a linux cluster, the speedup we
> > > > achieve
> > > > > with a fairly large problem size(million of
> > > > elements)
> > > > > is only 3 to 4 using the Congugate gradient
> > > > solver. We
> > > > > can achieve a speed up of a 6.5 using a GMRes
> > > > solver
> > > > > but the wall clock time of a GMRes is longer
> > than
> > > > a CG
> > > > > solver which indicates that CG is the faster
> > > > solver
> > > > > and it scales not as good as GMRes. Is this
> > > > generally
> > > > > true?
> > > > > I then went to the examples and find a 2D
> > example
> > > > of
> > > > > KSPSolve (ex2.c). I let the code ran with a
> > > > 1000x1000
> > > > > mesh and get a linear scaling of the CG solver
> > and
> > > > a
> > > > > super linear scaling of the GMRes. These are
> > both
> > > > much
> > > > > better than our code. However, I think the 2D
> > > > nature
> > > > > of the sample problem might help the scaling
> > of
> > > > the
> > > > > code. So I would like to try some 3D example
> > using
> > > > the
> > > > > KSPSolve. Unfortunately, I couldn't find such
> > an
> > > > > example either in the
> > > > src/ksp/ksp/examples/tutorials
> > > > > directory or by google search. There are a
> > couple
> > > > of
> > > > > 3D examples in the
> > > > but
> > > > > they   are about the SNES not KSPSolve. If
> > anyone
> > > > can
> > > > > provide me with such an example, I would
> > really
> > > > > appreciate it.
> > > > > Thanks a lot.
> > > > > Shi
> ____________________________________________________________________________________
> > > > > Finding fabulous fares is fun.
> > > > > Let Yahoo! FareChase search your favorite
> > travel
> > > > sites to find flight and hotel bargains.
> > http://farechase.yahoo.com/promo-generic-14795097
> > > 8:00? 8:25? 8:40? Find a flick in no time
> > > with the Yahoo! Search movie showtime shortcut.
> > > http://tools.search.yahoo.com/shortcuts/#news
> Looking for earth-friendly autos?
> Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center.
> http://autos.yahoo.com/green_center/
One trouble is that despite this system, anyone who reads journals widely
and critically is forced to realize that there are scarcely any bars to
eventual
publication. There seems to be no study too fragmented, no hypothesis too
trivial, no literature citation too biased or too egotistical, no design too
warped, no methodology too bungled, no presentation of results too
inaccurate, too obscure, and too contradictory, no analysis too
self-serving,
no argument too circular, no conclusions too trifling or too unjustified,
and
no grammar and syntax too offensive for a paper to end up in print. --
Drummond Rennie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070209/0b2ea7cb/attachment.htm>
