Option with HYPRE and KSP
Sun Apr 8 19:59:22 CDT 2007
On Mon, 9 Apr 2007, Ben Tay wrote:
> Hi,
> I am solving a poisson eqn and using hypre as a preconditioner has greatly
> increased the speed. I am trying to do some more tuning and I have some
> questions:
> 1. Is boomerAMG the only option?
  Yes, but all will suck on the poisson compared to boomeramg, so stick to
boomer
What are the other hypre conditioners
> available? Is there any documentation somewhere?
  Run with -help and check the hypre users manual
>Is hypre just a
> preconditioner or can it be a solver as well?
  Run with -ksp_type richardson to use it as a "solver"
> 2. what does the preonly in ksp_type mean? Is the eqns solved?
   It means apply the preconditioner ONCE, unless the preconditioner is
a direct solver it does not solve the equations. Richardson means run
some number of iterations of the preconditioner and can solve the equations
> 3. why can't I use bcgs  or bicg with hypre?
   hypre doesn't support applying the transpose of the preconditioner that
bcgs and bicg need?
> Also, can cg be used for
> non-symmetric matrix. It seems to work.
  Sometimes it works, but it is dangerous and not worth risking.
   Barry
> Thank you very much.
> Regards.
