Option with HYPRE and KSP
Ben Tay zonexo at gmail.com
Sun Apr 8 20:13:55 CDT 2007
Ok thank you very much
On 4/9/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mon, 9 Apr 2007, Ben Tay wrote:
> > Hi,
> > I am solving a poisson eqn and using hypre as a preconditioner has
> greatly
> > increased the speed. I am trying to do some more tuning and I have some
> > questions:
> > 1. Is boomerAMG the only option?
> Yes, but all will suck on the poisson compared to boomeramg, so stick to
> boomer
> What are the other hypre conditioners
> > available? Is there any documentation somewhere?
> Run with -help and check the hypre users manual
> >Is hypre just a
> > preconditioner or can it be a solver as well?
> Run with -ksp_type richardson to use it as a "solver"
> > 2. what does the preonly in ksp_type mean? Is the eqns solved?
>   It means apply the preconditioner ONCE, unless the preconditioner is
> a direct solver it does not solve the equations. Richardson means run
> some number of iterations of the preconditioner and can solve the
> equations
> > 3. why can't I use bcgs  or bicg with hypre?
>   hypre doesn't support applying the transpose of the preconditioner that
> bcgs and bicg need?
> > Also, can cg be used for
> > non-symmetric matrix. It seems to work.
> Sometimes it works, but it is dangerous and not worth risking.
>   Barry
> > Thank you very much.
> > Regards.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070409/4ebca96e/attachment.htm>
