memory bleeding
Jordi Marcé Nogué jordi.marce at upc.edu
Thu May 11 11:23:50 CDT 2006
Ok! thanks! It runs so good!!
I supposed it when I read yours fisrts mails but I tried it last day and
I didn't write the code correctly. When I have readed this mail I've
tried again and I've found the error!
jordi
En/na Matthew Knepley ha escrit:
> The code you have there will create a matrix for every loop iteration,
> and will only destroy one at the end. The new MatMatMult() interface
> has an argument which allows the user to pass in a matrix.
>    Matt
> On 5/10/06, *Jordi Marcé Nogué* <jordi.marce at upc.edu
> <mailto:jordi.marce at upc.edu>> wrote:
>     Yes, of course I destroy the matrix.... The scheme of my code when I
>     create a diagonal Mass-lumping matrix is the code below.
>     In MatSeqAIJSetPreallocation(M_aux1,6,PETSC_NULL); the number is 6
>     because in a general coordinates it's possible this matrix changes in a
>     6x6 full matrix.
>     "element3D *p_element = lfiber[i].getElement(e)"  is a internal
>     procedure to obtain information about the element
>     Mat M_aux1, M_aux2;
>     MatCreateSeqAIJ(PETSC_COMM_SELF, 6, 6, 6, PETSC_NULL, &M_aux1);
>     MatCreateSeqAIJ(PETSC_COMM_SELF, 6, 6, 6, PETSC_NULL, &M_aux2);
>     MatSeqAIJSetPreallocation(M_aux2,6,PETSC_NULL);
>     MatSetFromOptions(M_aux1);
>     MatSetOption(M_aux1, MAT_SYMMETRIC);
>     MatSetOption(M_aux1, MAT_IGNORE_ZERO_ENTRIES);
>     MatSetFromOptions(M_aux2);
>     MatSetOption(M_aux2, MAT_SYMMETRIC);
>     MatSetOption(M_aux2, MAT_IGNORE_ZERO_ENTRIES);
>     for(uint32_t i=0; i<nfiber;i++)
>          for(uint32_t e=0; e<lfiber[i].nelements;e++)
>           MatZeroentries(M_aux1);
>           MatZeroentries(M_aux2);
>           element3D *p_element = lfiber[i].getElement(e);
>           p_element->updateTs();
>           MatSetValue(M_aux1, 0, 0, p_element->L0 * value.pho / 6.,
>     INSERT_VALUES);
>           MatSetValue(M_aux1, 1, 1, p_element->L0 * value.pho / 6.,
>     INSERT_VALUES);
>           MatSetValue(M_aux1, 2, 2, p_element->L0 * value.pho / 6.,
>     INSERT_VALUES);
>           MatSetValue(M_aux1, 3, 3, p_element->L0 * value.pho / 6.,
>     INSERT_VALUES);
>           MatSetValue(M_aux1, 4, 4, p_element->L0 * value.pho / 6.,
>     INSERT_VALUES);
>           MatSetValue(M_aux1, 5, 5, p_element->L0 * value.pho / 6.,
>     INSERT_VALUES);
>           MatAssemblyBegin(M_aux1,MAT_FINAL_ASSEMBLY);
>           MatAssemblyEnd(M_aux1,MAT_FINAL_ASSEMBLY);
>           MatMatMult(M_aux1,p_element->T,&M_aux2);
>               MatMatMult(p_element->TT,M_aux2,&M_aux1);
>           // here I work with the matrix M_aux2, but in this point the
>     memory
>           // is constant. The code doesn't waste memory
>     MatDestroy(M_aux1);
>     MatDestroy(M_aux2);
>     Thanks,
>     best regards
>     Jordi Marcé-Nogué
>     Dept. Resistència de Materials i Estructures a l'Enginyeria
>     Universitat Politècnica de Catalunya (UPC)
>     Edifici T45 - despatx 137
>     ETSEIAT (Terrassa)
>     phone: +34 937 398 728
>     mail: jordi.marce at upc.edu <mailto:jordi.marce at upc.edu>
> "Failure has a thousand explanations. Success doesn't need one" -- Sir
> Alec Guiness
Jordi Marcé-Nogué
ETSEIAT (Terrassa)
