Program Design Question
Joshua L. Adelman jadelman at OCF.Berkeley.EDU
Mon May 8 11:05:36 CDT 2006
I am a new user of PETsc and was hoping that a more experienced
member of the group could give me some insight as to what would be
the proper formulation of the following problem in PETsc. I am
attempting to solve the simple ODE:
d{rho}/dt = K*rho
Where K is a large rate matrix that doesn't depend on time within the
simulation (i.e K(x)) and rho is a vector of densities. K is usually
stiff as it contains terms that reflect both diffusive and chemical
transitions, and its entries are sparse.   I am interested in the
evolution of the system in time as well as the steady-state behavior.
I have already implemented a version of the code in Matlab and am
looking to write a PETsc version that can be run in parallel on a
cluster. In my matlab code, setting up K is fast and the rate
limiting step is actually doing the solve.
Is the appropriate approach using the Backward Euler TS to solve the
problem? Also it is unclear to me whether I need to employ
Distributed Arrays (DA). I can provide more information about the
nature of the simulation if necessary if it helps in answering my
questions.
Any suggestions/insight would be most appreciated.
Josh
