memory bleeding
Wed May 10 08:24:10 CDT 2006
The code you have there will create a matrix for every loop iteration,
and will only destroy one at the end. The new MatMatMult() interface
has an argument which allows the user to pass in a matrix.
   Matt
On 5/10/06, Jordi Marcé Nogué <jordi.marce at upc.edu> wrote:
> Yes, of course I destroy the matrix.... The scheme of my code when I
> create a diagonal Mass-lumping matrix is the code below.
> In MatSeqAIJSetPreallocation(M_aux1,6,PETSC_NULL); the number is 6
> because in a general coordinates it's possible this matrix changes in a
> 6x6 full matrix.
> "element3D *p_element = lfiber[i].getElement(e)"  is a internal
> procedure to obtain information about the element
> Mat M_aux1, M_aux2;
> MatCreateSeqAIJ(PETSC_COMM_SELF, 6, 6, 6, PETSC_NULL, &M_aux1);
> MatCreateSeqAIJ(PETSC_COMM_SELF, 6, 6, 6, PETSC_NULL, &M_aux2);
> MatSeqAIJSetPreallocation(M_aux2,6,PETSC_NULL);
> MatSetFromOptions(M_aux1);
> MatSetOption(M_aux1, MAT_SYMMETRIC);
> MatSetOption(M_aux1, MAT_IGNORE_ZERO_ENTRIES);
> MatSetFromOptions(M_aux2);
> MatSetOption(M_aux2, MAT_SYMMETRIC);
> MatSetOption(M_aux2, MAT_IGNORE_ZERO_ENTRIES);
> for(uint32_t i=0; i<nfiber;i++)
>      for(uint32_t e=0; e<lfiber[i].nelements;e++)
>       MatZeroentries(M_aux1);
>       MatZeroentries(M_aux2);
>       element3D *p_element = lfiber[i].getElement(e);
>       p_element->updateTs();
>       MatSetValue(M_aux1, 0, 0, p_element->L0 * value.pho / 6.,
> INSERT_VALUES);
>       MatSetValue(M_aux1, 1, 1, p_element->L0 * value.pho / 6.,
> INSERT_VALUES);
>       MatSetValue(M_aux1, 2, 2, p_element->L0 * value.pho / 6.,
> INSERT_VALUES);
>       MatSetValue(M_aux1, 3, 3, p_element->L0 * value.pho / 6.,
> INSERT_VALUES);
>       MatSetValue(M_aux1, 4, 4, p_element->L0 * value.pho / 6.,
> INSERT_VALUES);
>       MatSetValue(M_aux1, 5, 5, p_element->L0 * value.pho / 6.,
> INSERT_VALUES);
>       MatAssemblyBegin(M_aux1,MAT_FINAL_ASSEMBLY);
>       MatAssemblyEnd(M_aux1,MAT_FINAL_ASSEMBLY);
>       MatMatMult(M_aux1,p_element->T,&M_aux2);
>           MatMatMult(p_element->TT,M_aux2,&M_aux1);
>       // here I work with the matrix M_aux2, but in this point the memory
>       // is constant. The code doesn't waste memory
> MatDestroy(M_aux1);
> MatDestroy(M_aux2);
> Thanks,
> best regards
> Jordi Marcé-Nogué
> Dept. Resistència de Materials i Estructures a l'Enginyeria
> Universitat Politècnica de Catalunya (UPC)
> Edifici T45 - despatx 137
> ETSEIAT (Terrassa)
> phone: +34 937 398 728
> mail: jordi.marce at upc.edu
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060510/c0ccc0e9/attachment.htm>
