memory bleeding
Jordi Marcé Nogué jordi.marce at upc.edu
Wed May 10 04:23:06 CDT 2006
Yes, of course I destroy the matrix.... The scheme of my code when I
create a diagonal Mass-lumping matrix is the code below.
In MatSeqAIJSetPreallocation(M_aux1,6,PETSC_NULL); the number is 6
because in a general coordinates it's possible this matrix changes in a
6x6 full matrix.
"element3D *p_element = lfiber[i].getElement(e)"  is a internal
procedure to obtain information about the element
Mat M_aux1, M_aux2;
MatCreateSeqAIJ(PETSC_COMM_SELF, 6, 6, 6, PETSC_NULL, &M_aux1);
MatCreateSeqAIJ(PETSC_COMM_SELF, 6, 6, 6, PETSC_NULL, &M_aux2);
MatSeqAIJSetPreallocation(M_aux2,6,PETSC_NULL);
MatSetFromOptions(M_aux1);
MatSetOption(M_aux1, MAT_SYMMETRIC);
MatSetOption(M_aux1, MAT_IGNORE_ZERO_ENTRIES);
MatSetFromOptions(M_aux2);
MatSetOption(M_aux2, MAT_SYMMETRIC);
MatSetOption(M_aux2, MAT_IGNORE_ZERO_ENTRIES);
for(uint32_t i=0; i<nfiber;i++)
     for(uint32_t e=0; e<lfiber[i].nelements;e++)
      MatZeroentries(M_aux1);
      MatZeroentries(M_aux2);
      element3D *p_element = lfiber[i].getElement(e);
      p_element->updateTs();
      MatSetValue(M_aux1, 0, 0, p_element->L0 * value.pho / 6.,
INSERT_VALUES);
      MatSetValue(M_aux1, 1, 1, p_element->L0 * value.pho / 6.,
INSERT_VALUES);
      MatSetValue(M_aux1, 2, 2, p_element->L0 * value.pho / 6.,
INSERT_VALUES);
      MatSetValue(M_aux1, 3, 3, p_element->L0 * value.pho / 6.,
INSERT_VALUES);
      MatSetValue(M_aux1, 4, 4, p_element->L0 * value.pho / 6.,
INSERT_VALUES);
      MatSetValue(M_aux1, 5, 5, p_element->L0 * value.pho / 6.,
INSERT_VALUES);
      MatAssemblyBegin(M_aux1,MAT_FINAL_ASSEMBLY);
      MatAssemblyEnd(M_aux1,MAT_FINAL_ASSEMBLY);
      MatMatMult(M_aux1,p_element->T,&M_aux2);
          MatMatMult(p_element->TT,M_aux2,&M_aux1);
      // here I work with the matrix M_aux2, but in this point the memory
      // is constant. The code doesn't waste memory
MatDestroy(M_aux1);
MatDestroy(M_aux2);
best regards
Jordi Marcé-Nogué
Dept. Resistència de Materials i Estructures a l'Enginyeria
Universitat Politècnica de Catalunya (UPC)
Edifici T45 - despatx 137
ETSEIAT (Terrassa)
phone: +34 937 398 728
mail: jordi.marce at upc.edu
