memory bleeding
Tue May 9 11:27:25 CDT 2006
Are you destroying the matrix created by MatMatMult()? From the webpage:
Notes C will be created and must be destroyed by the user with
MatDestroy<http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatDestroy.html#MatDestroy>().
Unless scall is MAT_REUSE_MATRIX
   Matt
On 5/9/06, Jordi Marcé Nogué <jordi.marce at upc.edu> wrote:
> Hi,
> I find my problem with the memory. Using  PetscTrDump(PETSC_NULL) I've
> cornered it and I've find the lines which generate it.
> I've discovered that the functions like MatTranspose(), MatMatMult() or
> similar functions creates extra memory in my code and these don't destroy.
> I explain:
> I create my matrices ----->>>>   3000 b are created (for example)
> I use MatMatMult --------->>>>   2000 bytes are created (for example)
> I destroy my matrices ---->>>>   3000 b are destroyed.
> How can I free the memory created in the function MaMatMult()?
> The final result is that if I use this function in a iterative process I
> full the memory of the box. If I multiply the matrix in a own function,
> I don't have this problem.
> best regards,
> jordi
> En/na Satish Balay ha escrit:
> > If you don't get any output with -trdump - it could mean that all
> > objects are getting properly destroyed. But the swap usage is a bit
> > unusual.
> > You could try the option -trmalloc_log to see how memory is allocate
> > on the PETSc side. And also -log_summary to see the summary of memory
> > usage.
> > Also - is it possible you have malloc() calls in your side of the code
> > - that could be leaking memory?
> > you could also comment out all MatSetOption() calls and see if it
> > makes a difference.
> > BTW: 2.2.0 is a very old version. You might want to upgrade to the
> > latest 2.3.1
> > Satish
> > On Mon, 8 May 2006, Jordi Marcé Nogué wrote:
> >>Thanks Barry,
> >>I'm using petsc 2.2.0. When I run my program ( " ./myprogram -trdump "
> or with
> >>-trmalloc, -trinfo...) I don't obtain anything... in the screen the code
> doesn't
> >>print
> >>anything.
> >>If I use (for example) "./myprogram -start_on_debugger", in my screen
> apers gdb
> >>and runs good... and with another options like -log_trace petsc writes
> messages
> >>in
> >>my screen. Would I have to activate something in my internal petsc code?
> >>best regards,
> >>jordi
> >>Missatge citat per Barry Smith <bsmith at mcs.anl.gov>:
> >>>    See
> http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> >>>number 12
> >>>    You can run for say a few iterations with the options
> >>>-malloc_debug -malloc_dump (in  PETSc 2.3.1. in early releases it had
> >>>different names). At PetscFinalize() PETSc will print all the memory
> >>>it has allocated that has not been freed and where it was allocated.
> >>>This can help determine what objects are not being freed.
> >>>    Barry
> >>>>Hi,
> >>>>I use PETSc, and after 5000 (more or less) iteations in which i solve
> a
> >>>little
> >>>>matrix
> >>>>(30x30) my swap is totally used!!! I'm sure that when I create my
> matrices
> >>>I
> >>>>destroy
> >>>>them. Could you help me about it? What happens? What thing I do bad?
> >>>>Mat K
> >>>>MatCreateSeqAIJ(PETSC_COMM_SELF, dim, dim, 9 , PETSC_NULL, &K);
> >>>>MatSetFromOptions(K);
> >>>>MatSetOption(K, MAT_SYMMETRIC);
> >>>>MatSetOption(K, MAT_ROW_ORIENTED);
> >>>>MatSetOption(K, MAT_IGNORE_ZERO_ENTRIES);
> >>>>MatSetOption(K, MAT_NEW_NONZERO_ALLOCATION_ERR);
> >>>>( I use KSP solve, created and destroyed)
> >>>>MatDestroy(K);
> >>>>Thanks,
> >>>>jordi
> >>>>Jordi Marcé-Nogué
> >>>>Dept. Resistència de Materials i Estructures a l'Enginyeria
> >>>>Universitat Politècnica de Catalunya (UPC)
> >>>>Edifici T45 - despatx 137
> >>>>ETSEIAT (Terrassa)
> >>>>phone: +34 937 398 728
> >>>>mail: jordi.marce at upc.edu
> Jordi Marcé-Nogué
> ETSEIAT (Terrassa)
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060509/1325b9b2/attachment.htm>
