[petsc-dev] Latest Pull breaks the 'test' target
Wed May 24 09:47:38 CDT 2023
On Wed, May 24, 2023 at 10:37 AM Barry Smith <bsmith at petsc.dev> wrote:
>   Ahh, are you using the default make that comes from Apple or do you use
> a modern gnumake (such as from brew?)
>   I get Jed's results with the brew one (installed as gmake) and your
> results with the Apple one /usr/bin/make
Yes, the Apple make. Argh.
   Matt
> On May 24, 2023, at 8:52 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, May 24, 2023 at 6:53 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, May 23, 2023 at 9:00 PM Jed Brown <jed at jedbrown.org> wrote:
>>> I use it that way all the time, but I can't reproduce.
>>> $ touch src/snes/interface/snes.c
>>> $ make test gs=snes_tutorials-ex5_1
>>>          CC ompi/obj/snes/interface/snes.o
>>> Using MAKEFLAGS: -j8 -l12 --jobserver-auth=fifo:/tmp/GMfifo1004133 --
>>>     CLINKER ompi/lib/libpetsc.so.3.019.1
>>>     CLINKER ompi/tests/snes/tutorials/ex5
>>>        TEST ompi/tests/counts/snes_tutorials-ex5_1.counts
>>>  ok snes_tutorials-ex5_1
>>>  ok diff-snes_tutorials-ex5_1
>> Does not work for me. This is incredibly frustrating:
>> bldenton/dmplex-cadrefactor *$:/PETSc3/petsc/petsc-dev$ touch
> Found it. For some reason, I need
>   make -f./gmakefile test
>   Matt
>> bldenton/dmplex-cadrefactor $:/PETSc3/petsc/petsc-dev$ make test
>> /usr/bin/make --no-print-directory -f
>> /PETSc3/petsc/petsc-dev/gmakefile.test PETSC_ARCH=arch-master-debug
>> PETSC_DIR=/PETSc3/petsc/petsc-dev test
>> /Library/Frameworks/Python.framework/Versions/3.8/bin/python3
>> /PETSc3/petsc/petsc-dev/config/gmakegentest.py
>> --petsc-dir=/PETSc3/petsc/petsc-dev --petsc-arch=arch-master-debug
>> --testdir=./arch-master-debug/tests
>> Using MAKEFLAGS: --no-print-directory --
>> PETSC_DIR=/PETSc3/petsc/petsc-dev PETSC_ARCH=arch-master-debug
>> gs=snes_tutorial
>> s-ex5_1
>>          CC arch-master-debug/tests/snes/tutorials/ex5.o
>>     CLINKER arch-master-debug/tests/snes/tutorials/ex5
>>        TEST arch-master-debug/tests/counts/snes_tutorials-ex5_1.counts
>>   Thanks,
>>     Matt
>>> Barry Smith <bsmith at petsc.dev> writes:
>>> >   Sure, I do also with make all; make test s="something"
>>> >    I have no idea how gmakefile.test dependencies work, you'll need to
>>> get Jed to fix the problem.
>>> >> On May 23, 2023, at 10:22 AM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> >> On Tue, May 23, 2023 at 10:22 AM Barry Smith <bsmith at petsc.dev
>>> <mailto:bsmith at petsc.dev>> wrote:
>>> >>>   I never knew there was such a dependency; I always ran make all ;
>>> make tests The gnumake stuff is still confusing to me so I have no idea how
>>> it works or why.
>>> >> I run single tests all the time. That is how I develop.
>>> >>    Matt
>>> >>>> On May 23, 2023, at 9:34 AM, Matthew Knepley <knepley at gmail.com
>>> <mailto:knepley at gmail.com>> wrote:
>>> >>>> The 'test' target no longer depends on 'libs' somehow so when I
>>> change source files they do not get rebuilt before my test runs. Why did we
>>> do this?
>>> >>>>   Thanks,
>>> >>>>     Matt
>>> >>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> >>>> -- Norbert Wiener
>>> >>>> https://www.cse.buffalo.edu/~knepley/ <
>>> http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> >> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230524/263ed72d/attachment-0001.html>
