[petsc-dev] Latest Pull breaks the 'test' target
Barry Smith bsmith at petsc.dev
Wed May 24 09:58:36 CDT 2023
  Also, Apple has super security around /usr/bin/make. If I copy /opt/homebrew/bin//gmake  to /opt/homebrew/bin//make and put it ahead of /usr/bin/make in the path
$ which -a make
/usr/bin/make
~/Src/petsc (barry/2023-05-14/add-fortran-petsccheck=) arch-add-fortran-petsccheck
$ make --version
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
It uses the /usr/bin/make
And I cannot delete /usr/bin/make
$ sudo rm -rf /usr/bin/make
rm: /usr/bin/make: Operation not permitted
So make at the command line always uses the old one provided by Apple; it does not use the /opt/homebrew/bin/make one
But if I copy /opt/homebrew/bin//gmake to ~/bin/make and put ~/bin first in my path then it defaults to using my copy
$ which -a make
/Users/barrysmith/bin//make
/usr/bin/make
$ make --version
GNU Make 4.4.1
Now I get Jed's behavior when I type make
This security feature of /usr/bin/make has been true on macOS for many years, I had just mostly forgotten about it since I had ~/bin first in my path
> On May 24, 2023, at 10:37 AM, Barry Smith <bsmith at petsc.dev> wrote:
>   Ahh, are you using the default make that comes from Apple or do you use a modern gnumake (such as from brew?)
>   I get Jed's results with the brew one (installed as gmake) and your results with the Apple one /usr/bin/make
>> On May 24, 2023, at 8:52 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, May 24, 2023 at 6:53 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>> On Tue, May 23, 2023 at 9:00 PM Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
>>>> I use it that way all the time, but I can't reproduce.
>>>> $ touch src/snes/interface/snes.c
>>>> $ make test gs=snes_tutorials-ex5_1
>>>>          CC ompi/obj/snes/interface/snes.o
>>>> Using MAKEFLAGS: -j8 -l12 --jobserver-auth=fifo:/tmp/GMfifo1004133 -- gs=snes_tutorials-ex5_1
>>>>     CLINKER ompi/lib/libpetsc.so.3.019.1
>>>>     CLINKER ompi/tests/snes/tutorials/ex5
>>>>        TEST ompi/tests/counts/snes_tutorials-ex5_1.counts
>>>>  ok snes_tutorials-ex5_1
>>>>  ok diff-snes_tutorials-ex5_1
>>> Does not work for me. This is incredibly frustrating:
>>> bldenton/dmplex-cadrefactor *$:/PETSc3/petsc/petsc-dev$ touch src/snes/interface/snes.c
>> Found it. For some reason, I need
>>   make -f./gmakefile test
>>   Matt
>>> bldenton/dmplex-cadrefactor $:/PETSc3/petsc/petsc-dev$ make test gs=snes_tutorials-ex5_1
>>> /usr/bin/make --no-print-directory -f /PETSc3/petsc/petsc-dev/gmakefile.test PETSC_ARCH=arch-master-debug PETSC_DIR=/PETSc3/petsc/petsc-dev test
>>> /Library/Frameworks/Python.framework/Versions/3.8/bin/python3 /PETSc3/petsc/petsc-dev/config/gmakegentest.py --petsc-dir=/PETSc3/petsc/petsc-dev --petsc-arch=arch-master-debug --testdir=./arch-master-debug/tests
>>> Using MAKEFLAGS: --no-print-directory -- PETSC_DIR=/PETSc3/petsc/petsc-dev PETSC_ARCH=arch-master-debug gs=snes_tutorial
>>> s-ex5_1
>>>          CC arch-master-debug/tests/snes/tutorials/ex5.o
>>>     CLINKER arch-master-debug/tests/snes/tutorials/ex5
>>>        TEST arch-master-debug/tests/counts/snes_tutorials-ex5_1.counts
>>>   Thanks,
>>>     Matt
>>>> Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> writes:
>>>> >   Sure, I do also with make all; make test s="something"
>>>> >    I have no idea how gmakefile.test dependencies work, you'll need to get Jed to fix the problem.
>>>> >> On May 23, 2023, at 10:22 AM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>> >> On Tue, May 23, 2023 at 10:22 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev> <mailto:bsmith at petsc.dev <mailto:bsmith at petsc.dev>>> wrote:
>>>> >>>   I never knew there was such a dependency; I always ran make all ; make tests The gnumake stuff is still confusing to me so I have no idea how it works or why.
>>>> >> I run single tests all the time. That is how I develop.
>>>> >>    Matt
>>>> >>>> On May 23, 2023, at 9:34 AM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com> <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>> wrote:
>>>> >>>> The 'test' target no longer depends on 'libs' somehow so when I  change source files they do not get rebuilt before my test runs. Why did we do this?
>>>> >>>>   Thanks,
>>>> >>>>     Matt
>>>> >>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>> >>>> -- Norbert Wiener
>>>> >>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>>>> >> -- Norbert Wiener
>>> -- Norbert Wiener
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230524/6c7cc298/attachment.html>
