[petsc-dev] Latest Pull breaks the 'test' target
Barry Smith bsmith at petsc.dev
Wed May 24 09:37:37 CDT 2023
  Ahh, are you using the default make that comes from Apple or do you use a modern gnumake (such as from brew?)
  I get Jed's results with the brew one (installed as gmake) and your results with the Apple one /usr/bin/make
> On May 24, 2023, at 8:52 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, May 24, 2023 at 6:53 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> On Tue, May 23, 2023 at 9:00 PM Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
>>> I use it that way all the time, but I can't reproduce.
>>> $ touch src/snes/interface/snes.c
>>> $ make test gs=snes_tutorials-ex5_1
>>>          CC ompi/obj/snes/interface/snes.o
>>> Using MAKEFLAGS: -j8 -l12 --jobserver-auth=fifo:/tmp/GMfifo1004133 -- gs=snes_tutorials-ex5_1
>>>     CLINKER ompi/lib/libpetsc.so.3.019.1
>>>     CLINKER ompi/tests/snes/tutorials/ex5
>>>        TEST ompi/tests/counts/snes_tutorials-ex5_1.counts
>>>  ok snes_tutorials-ex5_1
>>>  ok diff-snes_tutorials-ex5_1
>> Does not work for me. This is incredibly frustrating:
>> bldenton/dmplex-cadrefactor *$:/PETSc3/petsc/petsc-dev$ touch src/snes/interface/snes.c
> Found it. For some reason, I need
>   make -f./gmakefile test
>   Matt
>> bldenton/dmplex-cadrefactor $:/PETSc3/petsc/petsc-dev$ make test gs=snes_tutorials-ex5_1
>> /usr/bin/make --no-print-directory -f /PETSc3/petsc/petsc-dev/gmakefile.test PETSC_ARCH=arch-master-debug PETSC_DIR=/PETSc3/petsc/petsc-dev test
>> /Library/Frameworks/Python.framework/Versions/3.8/bin/python3 /PETSc3/petsc/petsc-dev/config/gmakegentest.py --petsc-dir=/PETSc3/petsc/petsc-dev --petsc-arch=arch-master-debug --testdir=./arch-master-debug/tests
>> Using MAKEFLAGS: --no-print-directory -- PETSC_DIR=/PETSc3/petsc/petsc-dev PETSC_ARCH=arch-master-debug gs=snes_tutorial
>> s-ex5_1
>>          CC arch-master-debug/tests/snes/tutorials/ex5.o
>>     CLINKER arch-master-debug/tests/snes/tutorials/ex5
>>        TEST arch-master-debug/tests/counts/snes_tutorials-ex5_1.counts
>>   Thanks,
>>     Matt
>>> Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> writes:
>>> >   Sure, I do also with make all; make test s="something"
>>> >    I have no idea how gmakefile.test dependencies work, you'll need to get Jed to fix the problem.
>>> >> On May 23, 2023, at 10:22 AM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>> >> On Tue, May 23, 2023 at 10:22 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev> <mailto:bsmith at petsc.dev <mailto:bsmith at petsc.dev>>> wrote:
>>> >>>   I never knew there was such a dependency; I always ran make all ; make tests The gnumake stuff is still confusing to me so I have no idea how it works or why.
>>> >> I run single tests all the time. That is how I develop.
>>> >>    Matt
>>> >>>> On May 23, 2023, at 9:34 AM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com> <mailto:knepley at gmail.com <mailto:knepley at gmail.com>>> wrote:
>>> >>>> The 'test' target no longer depends on 'libs' somehow so when I  change source files they do not get rebuilt before my test runs. Why did we do this?
>>> >>>>   Thanks,
>>> >>>>     Matt
>>> >>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> >>>> -- Norbert Wiener
>>> >>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>>> >> -- Norbert Wiener
>> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230524/c265ab61/attachment.html>
