[petsc-dev] Latest Pull breaks the 'test' target
Wed May 24 05:53:46 CDT 2023
On Tue, May 23, 2023 at 9:00 PM Jed Brown <jed at jedbrown.org> wrote:
> I use it that way all the time, but I can't reproduce.
> $ touch src/snes/interface/snes.c
> $ make test gs=snes_tutorials-ex5_1
>          CC ompi/obj/snes/interface/snes.o
> Using MAKEFLAGS: -j8 -l12 --jobserver-auth=fifo:/tmp/GMfifo1004133 --
>     CLINKER ompi/lib/libpetsc.so.3.019.1
>     CLINKER ompi/tests/snes/tutorials/ex5
>        TEST ompi/tests/counts/snes_tutorials-ex5_1.counts
>  ok snes_tutorials-ex5_1
>  ok diff-snes_tutorials-ex5_1
Does not work for me. This is incredibly frustrating:
bldenton/dmplex-cadrefactor *$:/PETSc3/petsc/petsc-dev$ touch
bldenton/dmplex-cadrefactor $:/PETSc3/petsc/petsc-dev$ make test
/usr/bin/make --no-print-directory -f
/PETSc3/petsc/petsc-dev/gmakefile.test PETSC_ARCH=arch-master-debug
PETSC_DIR=/PETSc3/petsc/petsc-dev test
/Library/Frameworks/Python.framework/Versions/3.8/bin/python3
/PETSc3/petsc/petsc-dev/config/gmakegentest.py
--petsc-dir=/PETSc3/petsc/petsc-dev --petsc-arch=arch-master-debug
--testdir=./arch-master-debug/tests
Using MAKEFLAGS: --no-print-directory -- PETSC_DIR=/PETSc3/petsc/petsc-dev
PETSC_ARCH=arch-master-debug gs=snes_tutorial
s-ex5_1
         CC arch-master-debug/tests/snes/tutorials/ex5.o
    CLINKER arch-master-debug/tests/snes/tutorials/ex5
       TEST arch-master-debug/tests/counts/snes_tutorials-ex5_1.counts
    Matt
> Barry Smith <bsmith at petsc.dev> writes:
> >   Sure, I do also with make all; make test s="something"
> >    I have no idea how gmakefile.test dependencies work, you'll need to
> get Jed to fix the problem.
> >> On May 23, 2023, at 10:22 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >> On Tue, May 23, 2023 at 10:22 AM Barry Smith <bsmith at petsc.dev <mailto:
> bsmith at petsc.dev>> wrote:
> >>>   I never knew there was such a dependency; I always ran make all ;
> make tests The gnumake stuff is still confusing to me so I have no idea how
> it works or why.
> >> I run single tests all the time. That is how I develop.
> >>    Matt
> >>>> On May 23, 2023, at 9:34 AM, Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
> >>>> The 'test' target no longer depends on 'libs' somehow so when I
> change source files they do not get rebuilt before my test runs. Why did we
> do this?
> >>>>   Thanks,
> >>>>     Matt
> >>>> What most experimenters take for granted before they begin their
> experiments lead.
> >>>> -- Norbert Wiener
> >>>> https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> >> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230524/3df8590c/attachment.html>
