[petsc-dev] Latest Pull breaks the 'test' target
Wed May 24 07:52:03 CDT 2023
On Wed, May 24, 2023 at 6:53 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, May 23, 2023 at 9:00 PM Jed Brown <jed at jedbrown.org> wrote:
>> I use it that way all the time, but I can't reproduce.
>> $ touch src/snes/interface/snes.c
>> $ make test gs=snes_tutorials-ex5_1
>>          CC ompi/obj/snes/interface/snes.o
>> Using MAKEFLAGS: -j8 -l12 --jobserver-auth=fifo:/tmp/GMfifo1004133 --
>>     CLINKER ompi/lib/libpetsc.so.3.019.1
>>     CLINKER ompi/tests/snes/tutorials/ex5
>>        TEST ompi/tests/counts/snes_tutorials-ex5_1.counts
>>  ok snes_tutorials-ex5_1
>>  ok diff-snes_tutorials-ex5_1
> Does not work for me. This is incredibly frustrating:
> bldenton/dmplex-cadrefactor *$:/PETSc3/petsc/petsc-dev$ touch
Found it. For some reason, I need
  make -f./gmakefile test
  Matt
> bldenton/dmplex-cadrefactor $:/PETSc3/petsc/petsc-dev$ make test
> /usr/bin/make --no-print-directory -f
> /PETSc3/petsc/petsc-dev/gmakefile.test PETSC_ARCH=arch-master-debug
> PETSC_DIR=/PETSc3/petsc/petsc-dev test
> /Library/Frameworks/Python.framework/Versions/3.8/bin/python3
> /PETSc3/petsc/petsc-dev/config/gmakegentest.py
> --petsc-dir=/PETSc3/petsc/petsc-dev --petsc-arch=arch-master-debug
> --testdir=./arch-master-debug/tests
> Using MAKEFLAGS: --no-print-directory -- PETSC_DIR=/PETSc3/petsc/petsc-dev
> PETSC_ARCH=arch-master-debug gs=snes_tutorial
> s-ex5_1
>          CC arch-master-debug/tests/snes/tutorials/ex5.o
>     CLINKER arch-master-debug/tests/snes/tutorials/ex5
>        TEST arch-master-debug/tests/counts/snes_tutorials-ex5_1.counts
>   Thanks,
>     Matt
>> Barry Smith <bsmith at petsc.dev> writes:
>> >   Sure, I do also with make all; make test s="something"
>> >    I have no idea how gmakefile.test dependencies work, you'll need to
>> get Jed to fix the problem.
>> >> On May 23, 2023, at 10:22 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> >> On Tue, May 23, 2023 at 10:22 AM Barry Smith <bsmith at petsc.dev
>> <mailto:bsmith at petsc.dev>> wrote:
>> >>>   I never knew there was such a dependency; I always ran make all ;
>> make tests The gnumake stuff is still confusing to me so I have no idea how
>> it works or why.
>> >> I run single tests all the time. That is how I develop.
>> >>    Matt
>> >>>> On May 23, 2023, at 9:34 AM, Matthew Knepley <knepley at gmail.com
>> <mailto:knepley at gmail.com>> wrote:
>> >>>> The 'test' target no longer depends on 'libs' somehow so when I
>> change source files they do not get rebuilt before my test runs. Why did we
>> do this?
>> >>>>   Thanks,
>> >>>>     Matt
>> >>>> What most experimenters take for granted before they begin their
>> experiments lead.
>> >>>> -- Norbert Wiener
>> >>>> https://www.cse.buffalo.edu/~knepley/ <
>> http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> >> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230524/549ed936/attachment-0001.html>
