[petsc-dev] Latest Pull breaks the 'test' target
Jed Brown jed at jedbrown.org
Tue May 23 20:00:33 CDT 2023
I use it that way all the time, but I can't reproduce.
$ touch src/snes/interface/snes.c
$ make test gs=snes_tutorials-ex5_1
         CC ompi/obj/snes/interface/snes.o
Using MAKEFLAGS: -j8 -l12 --jobserver-auth=fifo:/tmp/GMfifo1004133 -- gs=snes_tutorials-ex5_1
    CLINKER ompi/lib/libpetsc.so.3.019.1
    CLINKER ompi/tests/snes/tutorials/ex5
       TEST ompi/tests/counts/snes_tutorials-ex5_1.counts
 ok snes_tutorials-ex5_1
 ok diff-snes_tutorials-ex5_1
Barry Smith <bsmith at petsc.dev> writes:
>   Sure, I do also with make all; make test s="something"
>    I have no idea how gmakefile.test dependencies work, you'll need to get Jed to fix the problem.
>> On May 23, 2023, at 10:22 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, May 23, 2023 at 10:22 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>   I never knew there was such a dependency; I always ran make all ; make tests The gnumake stuff is still confusing to me so I have no idea how it works or why.
>> I run single tests all the time. That is how I develop.
>>    Matt
>>>> On May 23, 2023, at 9:34 AM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>> The 'test' target no longer depends on 'libs' somehow so when I  change source files they do not get rebuilt before my test runs. Why did we do this?
>>>>   Thanks,
>>>>     Matt
>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>> -- Norbert Wiener
