[petsc-dev] Latest Pull breaks the 'test' target
Barry Smith bsmith at petsc.dev
Tue May 23 09:34:31 CDT 2023
  Sure, I do also with make all; make test s="something"
   I have no idea how gmakefile.test dependencies work, you'll need to get Jed to fix the problem.
> On May 23, 2023, at 10:22 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, May 23, 2023 at 10:22 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>   I never knew there was such a dependency; I always ran make all ; make tests The gnumake stuff is still confusing to me so I have no idea how it works or why.
> I run single tests all the time. That is how I develop.
>    Matt
>>> On May 23, 2023, at 9:34 AM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>> The 'test' target no longer depends on 'libs' somehow so when I  change source files they do not get rebuilt before my test runs. Why did we do this?
>>>   Thanks,
>>>     Matt
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20230523/4b412440/attachment-0001.html>
